Ewelink ZigBee Door And Window Sensor Smart Home Security Wireless Burglar Alarm Door Contact Sensor Detector Works With Alexa
Regular price $14.76
Regular price $0 $14.76 Sale price
Low stock
Shop eWeLink ZigBee Smart Detection for Doors & Windows Secure Your Home Today
Enhance your home security with the eWeLink ZigBee Door Sensor, a compact and efficient device designed to monitor the opening and closing of doors and windows. This Wireless Entry Sensor ensures you're promptly notified of any unauthorized access, providing peace of mind whether you're at home or away.
  • ZigBee 3.0 Protocol: Utilizes the latest ZigBee 3.0 standard for reliable and secure communication with your smart home system.
  • Real-Time Alerts: Receive instant notifications on your smartphone via the eWeLink app whenever a door or window is opened or closed
  • Compact Design: With dimensions of 50 x 25 x 11 mm for the main body and 30 x 14 x 11 mm for the magnet, it blends seamlessly into any home décor
  • Long Battery Life: Powered by a CR2032 3V battery (included), it offers up to 1.5 years of operation under typical usage conditions
  • Wide Compatibility: Works harmoniously with Alexa and Google Assistant, allowing for voice-activated updates on your door and window status
The ZigBee Window Contact Sensor is straightforward to install using the provided double-sided adhesive tape. Simply attach the sensor to the door or window frame and the magnet to the corresponding moving part. Ensure both components are aligned properly for optimal performance. Integration with the eWeLink app allows you to monitor status changes remotely and set up automation scenarios
  • Enhanced Security: Stay informed about any unauthorized entries, bolstering your home's security measures
  • Smart Automation: Create automation routines, such as turning on lights when a door is opened, enhancing convenience and energy efficiency.
  • Peace of Mind: Monitor the status of your doors and windows in real time, ensuring they're secured when you're not around.
Additional Information
Please note that a ZigBee gateway is required for the sensor to function. The device operates within a temperature range of -10°C to 45°C, making it suitable for various environments. Its detection accuracy is ≥5mm, ensuring precise monitoring of door and window statuses
Ewelink ZigBee wireless door window sensor
