EU US UK Plug Zigbee Smart Plug 16A Energy Monitor Remote Control Timer Alexa Google Home for Electrical Sockets with Control
Regular price $21.55
Regular price $0 $21.55 Sale price
Zigbee Smart Plug 16A EU US UK Plug Energy Monitor Remote Control Timer Alexa Google Home for Electrical Sockets with Control
BSD61 Universal Zigbee Smart Plug with Energy Monitoring: Seamless Automation for EU/UK/US Homes
Upgrade your home’s intelligence with the BSD61 Universal Zigbee Smart Plug, designed for ultimate reliability and compatibility across EU, UK, and US outlets. This Zigbee-enabled smart plug offers energy monitoring, voice control, and robust automation features while ensuring long-term stability and low power consumption. Perfect for tech-savvy households seeking a secure, hub-connected smart home ecosystem.
Why Choose the BSD61 Zigbee Smart Plug?
  1. Zigbee-Powered Stability & Efficiency
    Unlike WiFi plugs, the BSD61 uses Zigbee 3.0 technology forlower latency, extended range, andminimal interference. It connects seamlessly to Zigbee hubs (e.g., Samsung SmartThings, Amazon Echo 4th Gen), enabling a mesh network that strengthens your entire smart home system.
  2. Universal Plug Design for Global Use
    No adapters needed! Compatible withEU Schuko (Type F), UK BS 1363 (Type G), and US NEMA 5-15 (Type A/B)outlets. Ideal for travelers, expats, or homes with mixed plug standards.
  3. 16A High-Capacity & Energy Monitoring
    Safely power heavy-duty appliances (heaters, air conditioners, tools) up to 16A. Track real-time and historical energy usage via theTuya/Smart Life Appto optimize consumption and reduce bills.
  4. Full Voice & App Control
    • Voice Commands: Works withAlexa, Google Assistant, SmartThings, Xiaomi, and more. Say,“Alexa, turn on the coffee maker”to start your day effortlessly.
    • Tuya/Smart Life App: Remotely control devices, create schedules, or share access with family members—all from your smartphone.
  5. Smart Automation Made Simple
    • Custom Schedules: Set your lights, fans, or holiday décor to auto-adjust based on time or sunrise/sunset.
    • Countdown Timer: Automatically shut off devices after a set period (e.g., turn off heaters after 1 hour).
    • Power Failure Memory: Restores previous settings after outages—no need to reprogram.
  6. Safety & Durability You Can Trust
    • Overload Protection: Instant power cutoff during voltage spikes to protect your devices.
    • Manual Switch: Physical button for quick control without the app.
    • 10-Year Lifespan: Engineered with fire-resistant PC material and rated for 100,000+ cycles.
Easy Setup in 4 Steps (Zigbee Hub Required)
Connect a Zigbee Hub: Use a compatible hub (e.g., Samsung SmartThings, Amazon Echo 4th Gen).
Download the Tuya/Smart Life App: Available on iOS/Android.
Add Device: Open the app, select“Add Device”, and follow the prompts to pair the plug with your hub.
Control & Customize: Create groups, set schedules, or enable voice commands—all within the app!
Technical Excellence for Demanding Homes
  • Voltage Range: 100-240V AC (50/60Hz) – works globally.
  • Climate Resilience: Operates in extreme temperatures (-20℃~50℃) and up to 80% humidity.
  • Low Power Usage: Consumes <1.3W during operation, 0.4W/h on standby.
  • Certified Safety: FCC/ROHS certified for worry-free use.
  • LED Indicators: Red (power status), Blue (Zigbee connection status).
Zigbee-Specific Tips for a Flawless Experience
Hub Compatibility Matters: Ensure your Zigbee hub supports theZigbee 3.0 protocol. Popular options include Samsung SmartThings, Amazon Echo (4th Gen), and Hubitat Elevate.
Optimal Placement: Keep the plug within30 meters (indoor)of your Zigbee hub for stable connectivity. Walls or metal structures may reduce range.
Mesh Network Advantage: Add more Zigbee devices (e.g., bulbs, sensors) to extend coverage and strengthen signal reliability.
Firmware Updates: Regularly check the Tuya app for updates to enhance performance and security.
⚠️No Direct WiFi Connection: This plug requires a Zigbee hub and does not connect directly to WiFi routers.
Perfect for Smart Home Enthusiasts Who Value:
Energy Savings: Monitor and cut wasteful power usage.
Whole-Home Control: Group devices by room or function (e.g., “Home Office” or “Christmas Lights”).
Future-Proof Design: Zigbee’s growing ecosystem ensures compatibility with new devices.
Transform your home into a responsive, energy-efficient space—order the BSD61 Zigbee Smart Plug today and experience the next level of automation!
Note: Zigbee hub sold separately. Check compatibility with your existing smart home system before purchase.
