Introducing the EISsound SOUNDAROUND Wi-Fi In-Ceiling Amplifier with Two 5.25 In. In-Ceiling Speakers - the perfect solution for your home entertainment needs! This versatile system allows you to stream music wirelessly from your smartphone or tablet, or connect via Bluetooth for an even smoother listening experience. The two powerful 5.25 inch in-ceiling speakers deliver crisp, clear audio with deep bass and rich tones, giving you the ultimate surround sound experience.
And with the easy-to-use app, you can control your music, adjust volume levels, and even set alarms right from your phone. Installation is a breeze, thanks to the sleek design and simple instructions. So whether you're hosting a party or just lounging at home, the EISsound SOUNDAROUND Wi-Fi In-Ceiling Amplifier with Two 5.25 In. In-Ceiling Speakers will take your entertainment to the next level.
Manufacturer Part #:
60351
UPC:
8436031618693
Dimensions:
6.89 W x 3.93 H x 1.45 D inches (175 W x 100 H x 37 D mm)
WiFi Transceiver:
2.4 GHz/ 5GHz
WiFi Streaming:
24 bits/ 192 KHz
WiFi Connection:
WPS/Webpage
WiFi Standards:
802.11a/b/g/n
Ethernet/LAN:
RF Antenna:
Internal
Voltage:
12 to 24 VDC
Consumption:
60W
Input Signal:
775 to 1000 Vrms
Speaker Impedance:
16/8/4 ohms
Speaker Audio Power:
12 VDC: 3.5W to 10W
15 VDC: 5.5W to 16W
24 VDC: 15W to 25W
Speaker Power Consumption:
12 VDC: 14W to 30W
15 VDC: 18W to 45W
24 VDC: 44W to 60W
