EISsound In-Wall Bluetooth Audio Receiver with Two 5 In. Speakers and Power Supply, White (U.S.)
Regular price $317.95
Regular price $317.95 Sale price
Shop EISsound In-Wall Bluetooth Audio Receiver with Two 5 In. Speakers and Power Supply (White Color)
Transform your living space into a concert hall with the EISsound In-Wall Bluetooth Audio Receiver with Two 5 In. Speakers and Power Supply, White (U.S.). This sleek and stylish device allows you to stream your favorite tunes wirelessly from your smartphone, tablet, or computer. The package includes two high-quality 5-inch speakers that deliver rich and immersive sound, as well as a power supply that ensures a seamless audio experience with the in-wall bluetooth audio receiver.
With its easy-to-install design, the EISsound In-Wall Bluetooth Audio Receiver is perfect for home theater systems, office spaces, and any room where you want to enjoy high-fidelity audio without the clutter of cables and wires. The white finish seamlessly blends with any decor, making this receiver a functional and aesthetic addition to your home or office.
Benefits, Characteristics and Features:
  • Wireless Streaming: Stream music wirelessly from any Bluetooth-enabled device with the bluetooth audio receiver.
  • High-Quality Sound: The included two 5-inch speakers provide rich and immersive sound, making it an excellent bluetooth audio receiver with speakers.
  • Easy Installation: Designed for easy in-wall installation, this in-wall bluetooth audio receiver eliminates the need for visible cables and wires.
  • Aesthetic Design: The white finish blends seamlessly with any decor, enhancing the look of your home or office.
  • Complete Package: Includes the Bluetooth audio receiver, two 5-inch speakers, and a power supply for a complete and hassle-free audio solution.
  • Seamless Integration: The in-wall bluetooth audio receiver fits perfectly into your walls, providing a clean and uncluttered look.
  • Versatile Use: Ideal for home theater systems, office spaces, and any room that requires high-quality audio.
  • Enhanced Audio Experience: Enjoy a rich and immersive audio experience with the high-quality 5-inch speakers.
  • Convenient and Easy to Use: Stream your favorite music wirelessly from your devices with ease.
  • Bluetooth Range: Up to 33 feet
  • Speaker Size: Two 5-inch speakers
  • Finish: White
  • Power Supply: Included
  • Compatibility: Bluetooth-enabled devices
Installation:
The bluetooth audio receiver with speakers is designed for quick and easy installation, fitting seamlessly into your wall for a clean look.
Sit back, relax, and let the EISsound In-Wall Bluetooth Audio Receiver fill your space with beautiful sound. Upgrade your audio experience today and enjoy high-fidelity music streaming with the convenience of Bluetooth technology.
Product Specs:
Manufacturer Part # 52809
UPC 8436031618662
Outputs Stereo Line, Right Speaker, Left Speaker, Amplifier Trigger
Speaker Impedance 4/8/16 ohms
Speaker Output 5W stereo max.
Speaker Color White
Other Connection Volume limitation and mono/stereo jumpers
LED Display Off: Disconnected and Audio Off
Bluetooth Blue Flashing – searching BT Device
Blue On – BT connected
Audio-In Red On – Audio-In Activated
Voltage Terminals VDC, GND Normal: 15Vdc, Max: 16Vdc
Consumption Demand Bluetooth Operation Minimum: 22mA, Normal: 111mA
Consumption Demand Jack 3.5mm Minimum: 22mA, Normal: 99mA
Input Signal Jack 3.5mm Normal: 100mVrms, Maximum: 550mVrms
Input Impedance Jack 3.5mm Minimum: 7Kohms, Maximum: 60Kohms
Output Signal Output 4 ohm Maximum: 5Wrms
Output Signal Output 8 ohm Maximum: 2.5Wrms
Output Signal Output 16 ohm Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4 Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4 Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance Maximum: 1Kohms
Left/Right Channel Separation Normal: 58dB
Passband Minimum: 45Hz, Maximum: 20,000Hz
Distortion Normal: 0.1%
SNR Normal: 84dB
Bluetooth Identification Number Minimum: 0000, Maximum: 9999
Bluetooth Class2 BT2.1 + EDR A2DP 1.2 AVRCP 1.4
Wireless Transceiver 2.4GHz RF Power Transmitter: 7 dBm
Dimensions (Exterior) 1.77 x 4.17 x 1.77 inches (45 x 106 x 45mm)
Dimensions (Cavity) 1.77 x 1.77 x .41 inches (45 x 45 x 36mm)
Dimensions (Face Cover) 1.30 x 2.60 inches (33 x 66mm)
Range 33 feet (10m)
Warranty 2-Year
