Experience high-quality sound with the EISsound In-Wall Bluetooth Audio Receiver. This sleek and stylish device comes with two 5-inch speakers and a power supply, making it the perfect addition to any home. With its easy-to-use Bluetooth connectivity, you can stream music wirelessly from your smartphone, tablet, or computer.
The in-wall design saves valuable space and provides a clean and seamless look. The speakers deliver clear and crisp audio, making it ideal for listening to your favorite music or watching movies. The EISsound In-Wall Bluetooth Audio Receiver is compatible with most Bluetooth-enabled devices and is easy to install, making it the perfect choice for anyone looking to enhance their audio experience. Upgrade your home entertainment system today with this top-quality audio receiver.
Manufacturer Part #:
5280D
UPC:
8436031618815
Outputs:
Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance:
4/8/16 ohms
Speaker Output:
5W stereo max.
Speaker Color:
White
Other Connection:
Volume limitation and mono/stereo jumpers
LED Display:
Off: Disconnected and Audio Off
Bluetooth:
Blue Flashing – searching BT Device
Bluetooth:
Blue On – BT connected
Audio-In:
Red On – Audio-In Activated
Voltage Terminals VDC, GND:
Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth:
Minimum: 22mA Normal: 111Vdc
Consumption Demand Jack 3.5mm:
Minimum: 22mA Normal: 99Vdc
Input Signal Jack 3.5mm:
Normal: 100mVrms Maximum: 550mVrms
Input Signal Jack 3.5mm Input Impedance:
Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm:
Maximum: 5Wrms
Output Signal Output 8 ohm:
Maximum: 2.5Wrms
Output Signal Output 16 ohm:
Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4:
Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance:
Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4:
Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance:
