EISsound In-Wall Bluetooth Audio Receiver with Two 5 In. Speakers and Power Supply, Black (E.U.)
Regular price $367.95
Regular price $367.95 Sale price
The EISsound In-Wall Bluetooth Audio Receiver is the ultimate solution for those who want a sleek and stylish audio system without any visible wires or bulky components. This receiver comes with two 5-inch speakers that can be easily installed into the wall, providing a seamless and elegant look. With Bluetooth connectivity, you can stream your favorite music directly from your smartphone, tablet, or computer, without any wires or cords.
The receiver also comes with a power supply, ensuring that you can enjoy uninterrupted audio for hours on end. The black finish adds a touch of sophistication to any room, making it perfect for both home and office use. With its easy installation and high-quality sound, the EISsound In-Wall Bluetooth Audio Receiver is the perfect addition to any modern audio setup.
Manufacturer Part #: 5285D
UPC: 8436031618846
Outputs: Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance: 4/8/16 ohms
Speaker Output: 5W stereo max.
Speaker Color: White
Other Connection: Volume limitation and mono/stereo jumpers
LED Display: Off: Disconnected and Audio Off
Bluetooth: Blue Flashing – searching BT Device
Bluetooth: Blue On – BT connected
Audio-In: Red On – Audio-In Activated
Voltage Terminals VDC, GND: Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth: Minimum: 22mA Normal: 111Vdc
Consumption Demand Jack 3.5mm: Minimum: 22mA Normal: 99Vdc
Input Signal Jack 3.5mm: Normal: 100mVrms Maximum: 550mVrms
Input Signal Jack 3.5mm Input Impedance: Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm: Maximum: 5Wrms
Output Signal Output 8 ohm: Maximum: 2.5Wrms
Output Signal Output 16 ohm: Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4: Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance: Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4: Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance: Maximum: 1Kohms
Left/Right Channel Separation: Normal: 58dB Passband: Minimum: 45Hz Maximum: 20000Hz
Distortion: Normal: 0.1%
SNR: Normal: 84dB
Bluetooth Identification Number: Minimum: 0000 Maximum: 9999
Bluetooth: Class2 BT2.1 + EDR A2DP 1.2 AVRCP 1.4
Wireless Transceiver: 2.4GHz RF Power Transmitter: 7 dBm
Dimensions: Exterior: 1.8 x 1.8 x 1.7 inches (45 x 45 x 42mm)
Cavity: 1.8 x 1.8 x 1.4 inches (45 x 45 x 36mm)
Face Cover: 1.8 x 1.8 inches (45 x 45mm)
Range: 33 feet (10m)
Warranty: 2-Year
