EISsound In-Wall Bluetooth Audio Receiver with Two 2.5 In. Speakers and Power Supply, White (U.S.)
Regular price $229.95
Regular price $229.95 Sale price
Transform any room in your home or office into a high-quality sound system with the EISsound In-Wall Bluetooth Audio Receiver. This sleek and stylish device easily installs into your wall, providing a discreet and space-saving solution to enhance your audio experience. With two 2.5 inch speakers and a powerful built-in amplifier, you can enjoy crystal clear sound for music, movies, and more. The Bluetooth connectivity allows you to easily stream audio from your smartphone, tablet, or other Bluetooth-enabled device, while the included power supply ensures stable and reliable performance. The white finish complements any decor, making it the perfect addition to any room. Upgrade your audio experience with the EISsound In-Wall Bluetooth Audio Receiver.
Manufacturer Part #: 5280A
UPC: 8436031618679
Outputs: Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance: 4/8/16 ohms
Speaker Output: 5W stereo max.
Speaker Color: White
Other Connection: Volume limitation and mono/stereo jumpers
LED Display: Off: Disconnected and Audio Off
Bluetooth: Blue Flashing – searching BT Device
Bluetooth: Blue On – BT connected
Audio-In: Red On – Audio-In Activated
Voltage Terminals VDC, GND: Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth Operation: Minimum: 22mA Normal: 111mA
Consumption Demand Jack 3.5mm: Minimum: 22mA Normal: 99mA
Input Signal Jack 3.5mm: Normal: 100mVrms Maximum: 550mVrms
Input Signal Jack 3.5mm Input Impedance: Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm: Maximum: 5Wrms
Output Signal Output 8 ohm: Maximum: 2.5Wrms
Output Signal Output 16 ohm: Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4: Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance: Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4: Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance: Maximum: 1Kohms
Left/Right Channel Separation: Normal: 58dB Passband: Minimum: 45Hz Maximum: 20,000Hz
Distortion: Normal: 0.1%
SNR: Normal: 84dB
Bluetooth Identification Number: Minimum: 0000 Maximum: 9999
Bluetooth: Class2 BT2.1 + EDR A2DP 1.2 AVRCP 1.4
Wireless Transceiver: 2.4GHz RF Power Transmitter: 7 dBm
Dimensions: Exterior: 1.77 x 4.17 x 1.77 inches (45 x 106 x 45mm)
Cavity: 1.77 x 1.77 x .41 inches (45 x 45 x 36mm)
Face Cover: 1.30 x 2.60 inches (33 x 66mm)
Range: 33 feet (10m)
Warranty: 2-Year
EISsound In-Wall Bluetooth Audio Receiver White U.S
