Experience high-quality audio without sacrificing space with the EISsound In-Wall Bluetooth Audio Receiver with Two 2.5 In. Speakers and Power Supply, White (E.U.). This sleek and compact audio receiver comes with two 2.5 inch speakers and a power supply, all designed to fit seamlessly into your wall for a discreet and minimalist look.
With Bluetooth connectivity, enjoy wireless audio streaming from any compatible device, and adjust volume and playback with the included remote control. The EISsound In-Wall Bluetooth Audio Receiver is perfect for small to medium-sized rooms, and its white finish complements any interior design. Upgrade your home audio system today with this innovative and space-saving device.
Manufacturer Part #:
5280C
UPC:
8436031618808
Outputs:
Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance:
4/8/16 ohms
Speaker Output:
5W stereo max.
Speaker Color:
White
Other Connection:
Volume limitation and mono/stereo jumpers
LED Display:
Off: Disconnected and Audio Off
Bluetooth:
Blue Flashing – searching BT Device
Bluetooth:
Blue On – BT connected
Audio-In:
Red On – Audio-In Activated
Voltage Terminals VDC, GND:
Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth:
Minimum: 22mA Normal: 111Vdc
Consumption Demand Jack 3.5mm:
Minimum: 22mA Normal: 99Vdc
Input Signal Jack 3.5mm:
Normal: 100mVrms Maximum: 550mVrms
Input Signal Jack 3.5mm Input Impedance:
Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm:
Maximum: 5Wrms
Output Signal Output 8 ohm:
Maximum: 2.5Wrms
Output Signal Output 16 ohm:
Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4:
Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance:
Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4:
Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance:
