EISsound In-Wall Bluetooth Audio Receiver with Power Supply, Black (E.U.)
Regular price $185.95
Regular price $185.95 Sale price
Enjoy high-quality wireless audio streaming with the EISsound In-Wall Bluetooth Audio Receiver with Power Supply. This sleek and stylish device is designed to seamlessly integrate with your home or office décor. It comes in a sleek black finish and is compatible with the E.U. power supply. This Bluetooth audio receiver allows you to stream music wirelessly from your smartphone, tablet, or other Bluetooth-enabled device. It supports high-quality audio codecs like aptX and AAC, ensuring that you get the best possible sound quality.
Installation is easy thanks to the in-wall design, which allows you to discreetly hide the receiver behind a wall or ceiling. The receiver also comes with a power supply, so you can start using it right away. Whether you're looking to upgrade your home theater system or simply want to enjoy wireless audio in your home or office, the EISsound In-Wall Bluetooth Audio Receiver is the perfect solution. And the specification of EISsound In-Wall Bluetooth Audio Receiver with Power Supply is below
Manufacturer Part #: 5285B
UPC: 8436031618822
Outputs: Stereo Line Right Speaker Left Speaker Amplifier Trigger
Speaker Impedance: 4/8/16 ohms
Speaker Output: 5W stereo max.
Other Connection: Volume limitation and mono/stereo jumpers
LED Display: Off: Disconnected and Audio Off
Bluetooth: Blue Flashing – searching BT Device
Bluetooth: Blue On – BT connected
Audio-In: Red On – Audio-In Activated
Voltage Terminals VDC, GND: Normal: 15Vdc Max: 16Vdc
Consumption Demand Bluetooth: Minimum: 22mA Normal: 111Vdc
Consumption Demand Jack 3.5mm: Minimum: 22mA Normal: 99Vdc
Input Signal Jack 3.5mm: Normal: 100mVrms Maximum: 550mVrms
Input Signal Jack 3.5mm Input Impedance: Minimum: 7Kohms Maximum: 60Kohms
Output Signal Output 4 ohm: Maximum: 5Wrms
Output Signal Output 8 ohm: Maximum: 2.5Wrms
Output Signal Output 16 ohm: Maximum: 1.5Wrms
Line Output Signal Terminals 65, 66, 4: Maximum: 1.82Vrms
Line Output Signal Terminals 65, 66, 4 Output Impedance: Maximum: 50ohm
Amplifier Trigger Signal Terminals 62, 4: Maximum: 14Vdc
Amplifier Trigger Signal Terminals 62, 4 Output Impedance: Maximum: 1Kohms
Left/Right Channel Separation: Normal: 58dB Passband: Minimum: 45Hz Maximum: 20000Hz
Distortion: Normal: 0.1%
SNR: Normal: 84dB
Bluetooth Identification Number: Minimum: 0000 Maximum: 9999
Bluetooth: Class2 BT2.1 + EDR A2DP 1.2 AVRCP 1.4
Wireless Transceiver: 2.4GHz RF Power Transmitter: 7 dBm
Dimensions: Exterior: 1.8 x 1.8 x 1.7 inches (45 x 45 x 42mm)
Cavity: 1.8 x 1.8 x 1.4 inches (45 x 45 x 36mm)
Face Cover: 1.8 x 1.8 inches (45 x 45mm)
Range: 33 feet (10m)
Warranty: 2-Year
