The Ecolink ZigBee PIR Sensor is a state-of-the-art motion detection device that brings advanced automation to your smart home. Utilizing passive infrared (PIR) technology, this ZigBee PIR Sensor is designed to accurately detect human presence and movement, making it ideal for automating security systems, lighting, and other smart home devices. With a detection range of up to 30 feet and a wide 120-degree field of view, the sensor provides reliable coverage in any space.
Compatible with most ZigBee home automation platforms, the Ecolink ZigBee PIR Sensor seamlessly integrates with your existing smart home setup. Whether it’s triggering automated lighting, adjusting your smart thermostat, or enhancing your home security system, this sensor adds convenience and control to your daily life.
Its low-profile design ensures it blends into any room without being obtrusive, while its long battery life minimizes the need for frequent replacements. Easy to install and versatile enough for both residential and commercial applications, the Smart PIR Sensor offers a reliable solution for automating and securing your space.
Key Features:
ZigBee PIR Sensor: Provides seamless integration with ZigBee-enabled home automation platforms, including security systems and smart lighting.
Wide Detection Range: Detects motion up to 30 feet away with a 120-degree field of view for maximum coverage.
Smart PIR Sensor: Automates lighting, security systems, and climate control with responsive motion detection.
Compact Design: Low-profile and easy to install, suitable for both home and commercial use.
Long Battery Life: Efficient battery usage means less frequent battery changes, offering long-term performance.
Benefits:
Automate Your Home: Use the Ecolink ZigBee PIR Sensor to trigger smart devices like lights and thermostats, adding convenience to your daily routine.
Enhanced Security: Detects movement to alert you of potential intruders and integrates with security systems for heightened protection.
Simple Integration: Compatible with a variety of ZigBee platforms, making it easy to add to your existing smart home ecosystem.
Energy Efficiency: Automate lighting to only turn on when needed, reducing energy waste.
The Ecolink ZigBee PIR Sensor is the perfect choice for smart home enthusiasts who want reliable motion detection and seamless automation. Enhance your home’s security and efficiency with this versatile Smart PIR Sensor and take your home automation to the next level.
