Dual Cat5e Cable, 1,000 Ft.
(5.00)5 Reviews
In Stock
$278.95
SKU: WR2CAT5E
The Dual Cat5e Cable is a high-quality networking cable that is perfect for both commercial and residential use. This cable is made from durable materials that ensure long-lasting performance and reliability. It features two twisted pairs of copper wires that are designed to reduce crosstalk and interference, resulting in a clear and stable network connection.
The cable is 1,000 feet long, making it ideal for large-scale installations. It comes in an easy-to-use pull box that allows you to quickly and efficiently install it without any tangles or knots. The cable is rated for 350 MHz and is capable of transmitting high-speed data up to 1 Gbps, making it perfect for applications such as streaming media, online gaming, and video conferencing.
The Dual Cat5e Cable is UL listed and meets all EIA/TIA standards, ensuring that it is safe and reliable to use. It is also RoHS compliant, meaning that it is free of hazardous materials and safe for the environment.
If you’re looking for a high-quality networking cable that is both durable and reliable, the Dual Cat5e Cable is the perfect choice. With its long length, high-speed data transmission, and easy-to-use pull box, it is the ideal solution for any networking installation.
Manufacturer Part #: CAT5E-S-BL
Sheath Printing: STRUCTURED CABLE PRODUCTS – – – P/N CAT5E-S – – – 2×ENHANCED CAT5E 350 MHz 4 PR 24 AWG SOLID ETL VERIFIED TO ANSI/TIA-568-C.2 CMR 4PR 23AWG 75C CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXX FEET MM/YY
Category: DUPLEX U/UTP CAT5e-4P-PVC
Test Standard: ISO/IEC11801, TIA-568-C.2 YD/T1019
Conductor Material: SOLID-Bare Copper
Conductor Nom. O.D.: 0.49 mm, ±0.005 mm
Insulation Material: HDPE
Insulation Diameter: 0.87 mm ± 0.04 mm
Insulation Color: Blue: White-Blue, Orange: White-Orange, Green: White-Green, Brown: White-Brown
Rip-Cord: Yes
Drain Wire: No
Sheath Thickness: 0.55 ±0.05 mm
Sheath External O.D.: (5.0/10.8) ± 0.4 mm
Sheath Surface: Clean, Frap, Satiation
Sheath Material: PVC (complies RoHS)
Sheath Color: Blue
Surface Printing: Letter Height: 3.0 mm ±0.3mm, Color: Black, Print Error / Space: =13.5 Mpa
Elongation: >=150 percent
Aging Period: 100°C x 24hrs x 7d
After Aging Tensile Strength: >=12.5 Mpa
After Aging Elongation: >=125 percent
Cold Bend Test: -20°C 4 hours; No Cracking
Electrical Characteristics (20°C): 1.0-100.0MHz, Characteristic Impedance: 100 ohms ±15 ohms
Delay Skew: <=45 ns/100m
DC Resistance Max: 9.5 ohms/100m
DC Conductor Resistance Unbalance Max: 5.0 percent
Back to Top
chatsimple
