Introducing the Dome Water Leak Sensor, the essential tool for safeguarding your home from costly water damage. This wireless Z-Wave leak sensor with a remote probe is designed to detect leaks before they escalate, allowing you to address issues promptly and efficiently. Whether it's under appliances or in hard-to-reach places like sump pumps, the Dome Leak Sensor ensures comprehensive water monitoring.
Features, Benefits, and Usage:
Advanced Leak Detection: The Dome Water Leak Sensor helps you cap leaks before they turn into gushes, protecting your home and saving you money on water-related repairs.
Wireless and Battery-Powered: This smart-home leak detector is battery-powered, making it easy to install anywhere without worrying about wiring or power outlets.
Low-Profile Design: The sleek design allows you to place the Dome Leak Sensor underneath appliances and in tight spaces where leaks are likely to occur.
4-Foot Remote Sensor Probe: The included remote probe extends the sensor's reach, making it easier to monitor water activity in difficult-to-access areas.
Customized Alerts: Connect the Dome Water Leak Sensor to your Vera hub to receive personalized alerts, enabling you to take immediate action and shut off main valves if necessary.
Comprehensive Water Monitoring: With the Dome Leak Sensor, you can monitor water lines throughout your home, ensuring you catch leaks early and prevent extensive damage.
Easy Installation: The wireless, battery-powered design makes installation a breeze, allowing you to set up the sensor wherever you need it most.
Enhanced Protection: By detecting leaks early, the Dome Water Leak Sensor helps you avoid costly repairs and maintain the integrity of your home.
Convenient Alerts: Receive real-time alerts on your connected Vera hub, so you can respond to potential water issues quickly and effectively.
Under Appliances: Place the Dome Water Leak Sensor beneath washing machines, dishwashers, and other appliances to detect leaks where they often occur.
Hard-to-Reach Areas: Use the 4-foot remote sensor probe to monitor water activity in areas like sump pumps, behind toilets, or under sinks.
Around Water Lines: Install the sensor near water lines to detect leaks early and prevent water damage throughout your home.
Upgrade your home protection with the Dome Water Leak Sensor and enjoy peace of mind knowing you're prepared for any water-related emergencies. Order yours today and keep your home safe from leaks and water damage.
