The Chief P Series Swing Arm Wall Display Mount is the perfect solution for anyone who wants to maximize their viewing experience. With a 37-inch extension, this mount allows you to easily adjust your display to the perfect angle for optimal viewing. The swing arm design provides a sleek and modern look while also allowing for easy access to cables and wires. This mount is compatible with most displays up to 55 inches and 125 pounds, ensuring a secure and stable hold. The Chief P Series Swing Arm Wall Display Mount is the perfect addition to any home theater or office space, providing both functionality and style.
Depth From Wall | 3.4″ (86 mm) |
Extension | 37″ (940 mm) |
Tilt/Roll | +5°, -17° / ±2.5° |
Swivel | Up to 90° left/right |
Height Adjustment | 1″ (25 mm) |
Lateral Shift | Up to 9″ (229 mm) |
Mounts on Studs | 16″ (406 mm) on-center with 4.5″ (114 mm) left/right lateral shift |
Dimensions (HxWxD) | 22.04″ x 39.5″ x 3.4″ (56 x 100.3 x 8.6 cm) |
Color | Black |
Weight Capacity | 200 lbs (90.7 kg) |
Channel Size Width Each Arm | 0.63″ (16 mm) |
Kaden Arabic (verified owner) –
Very well worth the money.
Nathaniel (verified owner) –
Good service.
Daniel (verified owner) –
The product is firmly packed.
Phoenix (verified owner) –
Ryan (verified owner) –
