Elevate your home’s safety and comfort with the “Centralite Micro Monitoring” bundle. This package includes a Micro Smart Door Sensor for easy-to-install security, alerting you when doors or windows are opened. Also featured is the 3-Series Micro Indoor Smart Motion Sensor, a compact unit that triggers lighting and HVAC adjustments upon detecting movement. Rounding out the bundle is the Temperature & Humidity Sensor, which helps your HVAC system adapt to real-time climate conditions for improved comfort and energy efficiency. All devices are designed for seamless smart home integration.
