The 3/4" Ball Valve is a brass component designed for seamless integration with your Water Shut-Off System. This valve connects to the cold-water inlet of your main water line, delivering efficient and reliable control over your home's water supply.
Standard 3/4" NPT Fittings: Compatible with industry-standard piping, allowing for straightforward installation.
Manual Control Handle: Optimized for extensive residential systems or commercial buildings needing higher water throughput.
