Shop BroadLink FastCon Smart Sensor Kit Microwave Motion Sensor
The BroadLink FastCon Smart Sensor Kit is a comprehensive solution designed to enhance home automation and security. This kit includes a radar motion sensor, door/window sensor, temperature and humidity sensor, and a hub, providing a seamless integration of devices to monitor and control your home environment.
The Security Sensor kit offers several features
- Radar Motion Sensor: Utilizes advanced radar and microwave technology to detect human presence with high sensitivity, covering a detection range of 5 meters and a 120° angle.
- Door/Window Sensor: Monitors the opening/closing status of doors or windows, sending instant alerts to your smartphone if unexpected activity is detected.
- Temperature and Humidity Sensor: This keeps track of your home’s environmental conditions, allowing you to monitor and adjust settings for optimal comfort.
The kit operates through the BroadLink FastCon App, enabling easy setup and control of all connected devices. By integrating the Microwave Motion Sensor, you can automate routines such as turning on lights when motion is detected or adjusting settings based on room occupancy. The Radar Security Sensor ensures precise motion detection, enhancing your home’s security measures.
Benefits of this kit include enhanced security through real-time monitoring and alerts, energy efficiency by automating device control based on occupancy, and improved home comfort by maintaining optimal environmental conditions. The system is compatible with Alexa, allowing for voice control and seamless integration into your existing smart home ecosystem.
Incorporating the BroadLink FastCon Smart Sensor Kit into your home provides a robust and user-friendly solution for advancing your home automation and security capabilities.
Smart Sensor Kit
– Temperature&Humidity SensorP
– Mini hub
BroadLink Sensor Kit
Work With
BroadLink Fastcon APP
Supported OS
iOS11/Android 5.1 and above
Mini Hub——GW4C
Communication
Wi-Fi 802.11 b/g/n (2.4GHz)
Power Input
5V DC / 1A (Micro USB)
Temperature Measurement
0-50℃
Humidity Measurement
≤80%RH
FCC ID
2ATEV-BL3357-P
Radar Motion Sensor——SR4M
Power Supply
DC 2.7-3V (2x AAA Batteries)(Buyer purchase)
Power Consumption
≤46uA (standby)/≤25mA (max)
Detection Range
5m, 120°
-10°C~ 45°C
≤85%RH
Door Sensor——SR4D
Battery
Low Battery Indication
Working Related Humidity
≤85% RH
Working Temperature
-10℃-45℃
Battery
CR2032(Buyer purchase)
Temp Measurement
0~60°C
0~99%RH
Net Weight
24g
Dimensions
44.5*44.5*13mm
There are no reviews yet.
