Shop Bellman & Symfon Visit Magnetic Switch for Door/Window
The Bellman & Symfon Visit Magnetic Switch for Door/Window is a critical component for enhancing the security of your home or office. Designed for seamless integration with the Bellman & Symfon Visit wireless alert system, this Magnetic Switch for Door and Magnetic Switch for Window is engineered to detect the opening or closing of doors and windows with precision. Once triggered, it promptly sends a signal to the Visit alert system, ensuring you are immediately notified through your preferred method, whether it’s a loud alarm, flashing lights, or a vibrating pager.
This Visit Magnetic Switch is not only reliable but also incredibly easy to install. Its compact design allows it to blend discreetly with your existing décor while providing robust security monitoring. Whether you’re looking to protect your home, office, or any other space, the Magnetic Switch for Door/Window offers an effective solution for ensuring that unauthorized access is instantly detected.
Built with durability in mind, the Bellman & Symfon Visit Magnetic Switch is a must-have for anyone serious about security. It adds an extra layer of protection to your environment, giving you peace of mind knowing that your property is safeguarded.
Uses for Bellman & Symfon Visit Magnetic Switch for Door/Window
Home Security: The Magnetic Switch for Door/Window is ideal for enhancing the security of your home by detecting unauthorized access through doors and windows.
Office Monitoring: It provides a reliable solution for monitoring entry points in offices, ensuring that any unauthorized opening is quickly detected and reported.
Assistance for the Hearing Impaired: Integrated with the Bellman & Symfon Visit system, it helps individuals with hearing impairments by alerting them to door or window activity through visual, auditory, or vibrating signals.
Vacation Home Monitoring: Ideal for securing vacation homes or secondary properties, ensuring you are alerted to any activity while you’re away.
Business Security: Can be used in retail or business settings to monitor access points after hours, providing an extra layer of protection.
Features of Bellman & Symfon Visit Magnetic Switch for Door/Window
Easy Installation: The Visit Magnetic Switch is designed for quick and hassle-free installation on any door or window.
Seamless Integration: Compatible with the Bellman & Symfon Visit wireless alert system, allowing for instant alerts when triggered.
Compact and Discreet Design: The small, sleek design blends seamlessly with your door or window frame, maintaining the aesthetic of your space.
Reliable Performance: Provides consistent and accurate detection of door and window openings, ensuring that you are always informed of any activity.
Versatile Alerts: When the Magnetic Switch for Door or Magnetic Switch for Window is activated, it can trigger various alert methods, including loud alarms, flashing lights, or vibrating pagers, depending on your preference.
Durable Construction: Built to withstand regular use, ensuring long-term reliability and security for your property.
Product Specs:
Connector
3.5mm Mono Jack Plug
Contact Breaker
Open: Close to magnet (max 1 cm)
Closed: At least 2 cm from magnet
