B29C-Smart Infrared Monitoring Tuya Zigbee PIR Infrared Detector PIR Infrared Detector
Regular price $32.69
Regular price $0 $32.69 Sale price
[Low Voltage Remind]When the battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.
[Intelligent Linkage safe]The PIR Motion sensor can be linked with other smart devices, simple steps to create Smart Home automation and mobile phone remote monitoring.
[Advanced Motion Sensor]Tuya Zigbee PIR detects human body or animals that are moving, 360° detection angle, 5-7m detection distance, can achieve real-time monitoring day or night. When tuya motion sensor detect movement, RED light will on with alert notification.
[Emergency Alert Push Function with Movement Detected]When there is movement detected, the movement tuya motion sensor alert notifications will be pushed to your phone, be aware of what's happening at home even when you're away.
[PIR Motion Sensor History Records]You can track the history of tuya motion sensor detector activities.
[There are two power supply modes]USB and battery.
Detection Range of 5-7 meters :The Tuya Zigbee PIR Motion Sensor Detector can detect movement up to 5-7 meters, making it perfect for monitoring large areas.
Compatible with for Alexa and for Google Assistant :This smart home automation system is compatible with for Alexa and for Google Assistant, allowing you to control your home automation system with your voice.
Wireless Connectivity :The Tuya Zigbee PIR Motion Sensor Detector uses wireless connectivity, making it easy to install and eliminating the need for messy cables.
Tips for purchase: This product is Zigbee version, Users must have/already bought a tuya zigbee hub to operate. If without a zigbee hub, then such model will not work.
Tuya Zigbee PIR Motion Sensor Detector Movement Sensor Smart Life APP Wireless Home Automation System Work with FOR Alexa google home.
USB input voltage:DC5V/ 2A
Battery:DC3V LR03x2(Not include battery)
Battery Input voltage:DC3V LR03
Static Current:≤35uA
Working current:≤15mA
zigbee operating frequency:2.400GHz-2.484GHz
Detection distance:6M
Detection angle:360 °
Installation method:ceiling /wall
Working temperature:-10℃-50℃
Working humidity:≤95%RH
Colour:As Shown
Material:Plastic
Package Contents:
1 x PIR Motion Sensor
