AUBESS Tuya Zigbee/Wifi Temperature Humidity Sensor Home Connected Thermometer Compatible with Smart Life Alexa Google Assistant
Regular price $132.38
Regular price $0 $132.38 Sale price
AUBESS ZigBee/WiFi Temperature & Humidity Sensor Indoor Thermometer hygrometer
Notes:
①ZigBee Version needs to be used with zigbee 3.0 gateway
②Battery not included.
APP Control: Compatible with Tuya & Smart Life App
Voice Control: Compatible with Amazon Alexa & Google Home Assistant
(Alexa only supports checking temperature and voice control)
Product name: Temperature and humidity sensor
Battery type: 2*AAA (Not included )
Product parameter: DC3V LR03
Quiescent current: ≤10uA
Alarm current: ≤15mA
Low voltage and undervoltage: ≤2.6V
Material: ABS
Product Weight: 30g
Temperature Measure Accuracy: ±1°C
Humidity Measure Accuracy: ±5%RH
The difference between the two versions:
ZigBee Version
Wi-Fi Version
Wireless Technology
ZigBee
Wi-Fi 2.4GHz IEEE 802.11 b/g/n
Battery life
More than 6 months
More than 2 months
Data update frequency
Every 10 minutes or Temperature changes exceed 0.5 degrees Celsius or humidity changes exceeding 5% (Not customizable)
Once 1 hour or Temperature changes exceed 0.5 degrees Celsius or humidity changes exceeding 5%. (Not customizable)
Gateway
Gateway required
No gateway required
Description:
【Intelligent Linkage】
When the ambient environment change, you can do intelligent linkage. For example, the air conditioner will be on and turn to specified temperature automatically when the room temperature surpass 28℃. And the humidifier will spray when the humidity is lower than 20% RH.
【Share devices】
You can share your added devices with your family members, so they can also monitor the ambient environment.
【Temperature Unit Selection in APP】
You can choose ℃ or ℉ as the temperature unit through app.
【 Third-party Voice Control】
Works with amazon alexa, google assistant.
【Low battery alarm】
The battery level can be monitored.
【Temperature and humidity changes.】
Temperature and humidity change curve, historical data.
【Wall-mounted, easy to install】
Package Included:
1*Temperature humidity sensor
1*User Manual
1*Accessories package
