Shop Aqara Door and Window Sensor P1 Zigbee 3.0 Sensor Smart Protection for Your Home
The Aqara Door and Window Sensor P1 is a cutting-edge smart home device designed to enhance your home's security and automation. By detecting the real-time status of your doors and windows, this sensor ensures you're immediately alerted to any unauthorized access, serving as an effective anti-theft alarm.
Extended Battery Life: Equipped with a CR123A battery, the sensor boasts an impressive battery life of up to five years, minimizing maintenance needs.
Adjustable Detection Distance: The sensor allows customization of the detection distance between the sensor and magnet (10mm, 20mm, or 30mm) via the Aqara app, ensuring compatibility with various door and window types.
Tamper-Proof Design: Any attempt to remove or tamper with the sensor triggers an instant push notification, enhancing security measures.
Smart Home Integration: Compatible with Apple HomeKit and utilizing the Zigbee 3.0 protocol, the sensor seamlessly integrates with other smart devices, enabling automated scenarios like turning on lights upon door entry.
Installing the Aqara Door Sensor or Aqara Window Sensor on your doors and windows provides real-time monitoring, sending immediate alerts to your smartphone if unauthorized access is detected. This proactive approach to home security acts as an effective anti-theft alarm, deterring potential intruders and ensuring peace of mind.
Beyond security, the sensor enhances home automation. For instance, integrating the sensor with other Aqara devices allows you to set up scenarios where opening a door triggers lights to turn on, adding convenience and energy efficiency to your daily routines.
Installation
The sensor's compact and wireless design ensures a straightforward installation process. Simply peel and stick the sensor unit and magnet on the desired door or window, ensuring the maximum detection distance aligns with your setup.
