The Aprilaire Wi-Fi Thermostat with IAQ Control is the perfect solution for controlling your home’s indoor air quality. This advanced thermostat offers easy-to-use Wi-Fi connectivity, allowing you to remotely adjust your home’s temperature and humidity levels from anywhere using your smartphone or tablet.
The thermostat is equipped with intuitive controls and a large, backlit display that makes it easy to read and adjust.
It also features advanced IAQ Control technology, which allows you to monitor and control your home’s indoor air quality, including humidity levels and air purity.
With its sleek, modern design and easy-to-use features, the Aprilaire Wi-Fi Thermostat with IAQ Control is the perfect addition to any home. Whether you’re looking to improve your indoor air quality or simply want to control your home’s temperature from anywhere, this advanced thermostat is the ideal solution.
Manufacturer Part #: | 8910W |
UPC: | 686720891090 |
Digital Display: | 10.3-inch touchscreen |
Wireless Technology: | Wi-Fi |
Voice Control: | Amazon Alexa and Google Assistant |
Controls & Display Main Menu: | Set Schedule Button Clean Screen Set Vacation Set Current Time and Date Done Button (Exit Menu) User System Settings |
Approvals: | FCC |
Warranty: | 5-Year Limited |
Liam (verified owner) –
Good quality.
Riley (verified owner) –
The product is firmly packed.
Henry (verified owner) –
Very fast delivery.
Dylan (verified owner) –
Good quality.
Samuel (verified owner) –
Very well worth the money.
