AprilAire Model 8446 Digital Thermostat
(5.00)5 Reviews
Out of Stock
$32.95
SKU: RP8446
Brands:
The AprilAire Model 8446 Digital Thermostat is an advanced and user-friendly device designed to optimize your home’s heating and cooling system. With its sleek and modern design, this thermostat features a large digital display that is easy to read and navigate.
The AprilAire Model 8446 Digital Thermostat is equipped with advanced programming capabilities that allow you to create customized heating and cooling schedules for each day of the week. Additionally, this thermostat features a built-in humidity sensor that helps regulate the moisture levels in your home, ensuring a comfortable and healthy living environment.
With its simple installation process, the AprilAire Model 8446 Digital Thermostat can be easily integrated into your existing HVAC system. It is compatible with most heating and cooling systems, including gas, electric, and heat pump systems.
Overall, the AprilAire Model 8446 Digital Thermostat is an excellent choice for homeowners looking to upgrade their HVAC system with a reliable and high-performance thermostat. Its advanced features, modern design, and ease of use make it a top choice for homeowners looking to optimize their home‘s comfort and energy efficiency.
Manufacturer Part #: 8446
UPC: 686720844607
Applicable HVAC Systems: Standard systems gas, oil, electric Single stage/heat pump/multi-stage Millivolt systems
Thermal Control Range: 45° to 99°F (7° to 32°C)
Display Range: 32° to 99°F (0° to 40°C)
Accuracy: ± 1°F (± 0.5°C)
Storage Temperature: -30° to 140°F (-34.4° to 60°C)
Operating Humidity: 5% to 90% relative humidity
Operating Ambient Temperature: 32° to 120°F (0° to 48.9°C)
Shipping Temperature Range: 30° to 140°F (-34.4° to 60°C)
Electrical: 24 VAC (18-30 VAC), 1 amp maximum load per terminal, 2.5 amp total maximum load (all terminals)
AC Power: 18-30 Volt AC
Dimensions: 5.25 H x 4.50 W x 1.00 D inches
Approvals: FCC, IC
Warranty: 5-Year Limited
Customers Reviews
(5)
  1. Dominic (verified owner)
    The product is firmly packed.
    1 product
  2. Mateo (verified owner)
    Very fast delivery.
    1 product
  3. Riley (verified owner)
    Very well worth the money.
    1 product
  4. Aadarsh (verified owner)
    Very fast delivery.
    1 product
  5. Nolan (verified owner)
    Good quality.
    1 product
Back to Top
chatsimple
