The AprilAire Model 8444 Digital Thermostat is a sleek and modern thermostat that will add both style and functionality to your home. With its large, easy-to-read digital display and intuitive controls, this thermostat makes it easy to set the perfect temperature for your home. It features programmable settings that allow you to customize your heating and cooling preferences throughout the day and night, and its energy-saving features can help you save money on your utility bills.
The AprilAire Model 8444 Digital Thermostat is also compatible with a variety of heating and cooling systems, making it a versatile choice for any home. Whether you’re upgrading your current thermostat or installing a new one, the AprilAire Model 8444 Digital Thermostat is the perfect choice for anyone who wants a high-quality, reliable, and easy-to-use thermostat.
Manufacturer Part #: | 8444 |
UPC: | 686720844409 |
Applicable HVAC Systems: | Standard systems gas, oil, electric Single stage/heat pump/multi-stage Millivolt systems |
Thermal Control Range: | 45° to 99°F (7° to 32°C) |
Display Range: | 32° to 99°F (0° to 40°C) |
Accuracy: | ± 1°F (± 0.5°C) |
Storage Temperature: | -30° to 140°F (-34.4° to 60°C) |
Operating Humidity: | 5% to 90% relative humidity |
Operating Ambient Temperature: | 32° to 120°F (0° to 48.9°C) |
Shipping Temperature Range: | 30° to 140°F (-34.4° to 60°C) |
Electrical: | 24 VAC (18-30 VAC), 1 amp maximum load per terminal, 2.5 amp total maximum load (all terminals) |
AC Power: | 18-30 Volt AC |
Dimensions: | 5.25 H x 4.50 W x 1.00 D inches |
Approvals: | FCC, IC |
Warranty: | 5-Year Limited |
Isaac (verified owner) –
Very well worth the money.
Hayden (verified owner) –
The product is firmly packed.
Aiden (verified owner) –
Good quality.
Mason (verified owner) –
Nathaniel (verified owner) –
