The Aprilaire Flush-Mount Temperature & Humidity Sensor Support Module is a top-of-the-line device that allows you to easily monitor the temperature and humidity levels in your home or office. This module is designed to work seamlessly with Aprilaire thermostats, making it the perfect addition to your HVAC system. With its flush-mount design, it blends in seamlessly with your walls or ceiling, giving your space a sleek and modern look. The module provides accurate and reliable readings, ensuring that your home or office is always comfortable and healthy. Whether you’re looking to improve your indoor air quality or simply want to keep your space at the perfect temperature, the Aprilaire Flush-Mount Temperature & Humidity Sensor Support Module is the ideal solution.
Manufacturer Part #: | 8083 |
UPC: | 686720808302 |
Temperature: | -40° to 130°F (-40° to 55°C) |
Temperature Accuracy: | Comfort Range: ±1°F; 60° to 80°F Control Range: ±2°F; 40° to 100°F |
Humidity: | 0 to 99 percent R.H. (non-condensing) |
Humidity Accuracy: | ±5 percent R.H.; 20 to 80 percent R.H. |
Electrical Operating Voltage: | 24VAC (18 to 30VAC) |
Max. Wire Length from Module to Thermostat: | 1,000 feet |
Mateo (verified owner) –
Good quality.
Isaac (verified owner) –
Good quality.
Samuel (verified owner) –
Very fast delivery.
Camden (verified owner) –
Very well worth the money.
Tyler (verified owner) –
Very fast delivery.
