AprilAire 8466 Universal Programmable Thermostat
0 Reviews
In Stock
$97.95
SKU: RP8466
Customize HVAC Schedules For Every Day of the Week
Control virtually any HVAC or heat pump system the AprilAire 8466 Universal Programmable Thermostat. This programmable thermostat can command nearly any type of HVAC unit, including single stage systems, multi stage systems, and heat pumps systems. The thermostat’s 4.5 LCD screen displays indoor, target, and outdoor (via 8052 outdoor sensor, sold separately) temperatures, as well as notifications, messaging, and adjustable settings. This programmable model allows for separate temperature programming for each day of the week, all of which is saved to the thermostat and retained even when power is lost.
  • Programmable thermostat commands single or multistage HVAC systems
  • 4.5″ LCD display presents easy to read measurements, messaging, and settings
  • Works with conventional and heat pump HVAC systems, plus fan control with fan circulation mode
  • At-will temperature control can override programmed schedules
  • Displays time, room temperature, target temperature setting, and optional outdoor temperature
  • Can be AC powered, battery operated, or both (battery backup for clock)
  • Internal memory backup retains settings in case of power interruption
  • Optional outdoor and/or indoor temperature reporting with additional sensors (8051, 8052, or 8053, sold separately)
  • Progressive recovery allows the thermostat to activate the heating and cooling equipment prior to an event in order to reach the desired temperature at the start of the next scheduled event
Prep Your Home for Scheduled Events with Intelligent Automation
This AprilAire Thermostat offers 5/1/1 or 5/2 day programming, allowing you to set separate temperature schedules for your week and weekend to match your routines.
AprilAire’s “progressive recovery” activates your heating or cooling equipment before a scheduled event, so that when it’s time for the event to start, your home has already reached your desired temperature. Program the thermostat to remember what time you arrive home from work, and it can automatically prep the house before you reach your front door.
Contents
  • Thermostat
  • Mounting Hardware
NOTE: Professional installation recommended.
AprilAire: Feel Good, Inside
It is the mission of AprilAire to provide superior Indoor Air Quality products for new and existing homes and businesses. AprilAire products are built to provide you and your family with the most comfortable home and the cleanest, healthiest air possible. Protect your home and your most valuable possession – your family.
Product Specifications:
  • Manufacturer Part #: 8466
  • UPC: 686720846601
  • Applicable HVAC Systems:
    • Standard systems gas, oil, electric
    • Single stage/heat pump/multi-stage
    • Millivolt systems
Thermal
  • Control Range: 45° to 99°F (7° to 32°C)
  • Display Range: 32° to 99°F (0° to 40°C)
  • Accuracy: ± 1°F (± 0.5°C)
  • Storage Temperature: -30° to 140°F (-34.4° to 60°C)
  • Operating Humidity: 5% to 90% relative humidity
  • Operating Ambient Temperature: 32° to 120°F (0° to 48.9°C)
  • Shipping Temperature Range: 30° to 140°F (-34.4° to 60°C)
  • Electrical:
    • 24 VAC (18-30 VAC)
    • 1 amp maximum load per terminal
    • 2.5 amp total maximum load (all terminals)
  • AC Power: 18-30 Volt AC
  • Dimensions: 5.25 H x 4.50 W x 1.00 D inches
  • Approvals: FCC, IC
  • Warranty: 5-Year Limited
Back to Top
chatsimple
