Afourt-Tuya Zigbee Smart Light Sensor Illuminance Brightness Detection Home Lighting Automation Zigbee Intelligent Remote Alarm
Regular price $25.19
Regular price $0 $25.19 Sale price
Linkage with smart bulb Reading in dim light is an unhealthy eye habit, and the linkage of light sensors and smart light bulbs will be the best partner to ensure eye safety
Smart linkage to build ideal living space Are you still troubled by the tedious task of turning on the lights manually, or opening and closing the curtains? Light sensors links up with your smart devices to help you solve home problems.
Intelligentize whole house Real-time monitoring of the light intensity received by the home. When it gets dark, it will turn on smart lights for you to illuminate the path under your feet and ensure your safety.
A bridge connecting Zigbee device informationThe gateway can receive signals from ZigBee devices.Upload it to the server over a Wi-Fi network.Not only can you see real-time status on the app side,but you can also receive notification pushes. It also provides remote control and intelligent connectivity.
Stick anywhere you need With adhesive tape on the back, the smart light sensor can be sticked to anywhere you need.
TECHNICAL SPECIFICATIONS
Working frequency: Real-time reporting
Product name: Light sensor
Wireless connection: Zigbee
Low battery warning: Yes
Working temperature: -10℃-+50℃
Battery specifications: CR2032 (replaceable)
Detection range: 0-1000Lux
Colour:White
Material:ABS+PC
Package Contents:
1 * Intelligent Light Sensor
1 * mounting accessory tool
