Aeotec Zigbee Water Leak Sensor
Regular price $39.99
Regular price $39.99 Sale price
Low stock
Shop Water Leak Sensor at Best Price
The Aeotec Zigbee Water Leak Sensor is an essential device for safeguarding your home or office against water damage. Compact yet powerful, this sensor leverages Zigbee technology to seamlessly integrate with your smart home system, ensuring you receive immediate alerts if it detects water leaks or unusually high humidity levels.
Designed with both functionality and aesthetics in mind, the zigbee water leak sensor features a built-in alarm that sounds when water is detected, giving you an audible warning even when you’re nearby. Additionally, it sends instant notifications to your smartphone or tablet via the Aeotec app, allowing you to take prompt action no matter where you are.
Installation is straightforward, making it easy for anyone to set up and start using the zigbee leak detector. Whether placed under sinks, near water heaters, or in basements, this sensor provides reliable protection, helping you prevent costly water damage before it escalates.
Key Features:
  • Zigbee Connectivity: Ensures quick communication with your smart home system for real-time alerts.
  • Built-in Alarm: Provides an audible warning when water or high humidity is detected.
  • Smart Notifications: Sends alerts directly to your smartphone or tablet via the Aeotec app.
  • Easy Installation: Simple setup process makes it user-friendly and convenient to install.
  • Compact Design: Blends seamlessly into your home or office environment without being obtrusive.
Usage:
The sensors to detect water leakage are best utilized in areas prone to water exposure, such as basements, under sinks, behind appliances, or near water heaters. The sensor is designed to detect even the smallest amount of water, ensuring you’re alerted to potential leaks before they cause significant damage.
Benefits:
  • Prevent Water Damage: Detect leaks early and take action to avoid costly repairs.
  • Peace of Mind: Know that your property is monitored 24/7 with real-time alerts and notifications.
  • Energy Efficient: Low power consumption ensures long battery life, minimizing maintenance needs.
Aeotec Zigbee Water Sensor - Reliable Leak Detection Device
