Aeotec Water Sensor 7 Pro 3-in-1 Including Leak & Flood Temperature and Humidity Sensors
Regular price $46.90
Regular price $46.90 Sale price
Shop Aeotec Water Sensor 7 Pro: Leak, Flood, Temperature and Humidity Sensors
The Aeotec Water Sensor 7 Pro is the ultimate solution to detect and prevent water damage in your home or office. This 3-in-1 device includes leak and flood sensors, temperature sensors, and humidity sensors, providing a comprehensive monitoring system for your water-related needs. Shop this Aeotec Water Multi-sensor at best price from Ezlo.
With its advanced technology, the sensor can detect even the slightest water leak or flood, sending real-time alerts to your smartphone or email, allowing you to take immediate action. The temperature and humidity sensors can also help you maintain a comfortable and healthy living environment by monitoring the indoor temperature and humidity levels.
The Aeotec Water Sensor 7 Pro is easy to install and compatible with most smart home systems, making it an ideal investment for your home or office security system. Stay protected and keep your property safe with the Aeotec Water Sensor 7 Pro. The Aeotec Water Sensor 7 Pro boasts advanced leak detection capabilities. Its stainless-steel sensing tip can identify minuscule amounts of water (as little as 0.02 inches) on a surface, ensuring even the smallest leaks are promptly identified. Be informed immediately in case of a leak or environmental concern. The Aeotec Water Sensor 7 Pro sends real-time alerts to your smartphone or email, allowing you to take swift action to prevent further damage.
Product Specs of Aeotec Water 3 in 1 Sensor
Manufacturer Part #: ZWA019
UPC: 810667025335
Z-Wave Version: 7.12 or later
Smart Start: Yes
Repeater: No
Beaming Capable: No
Security Supported: S2 Unauthenticated, S2 Authenticated
Operating Distance: Approx 164 feet indoors, Up to 492 feet outdoors
Probe Wire Length: 4.9ft (1.5m)
Dimensions: 2.76 x 0.51 x .79 inches (70 x 13 x 20 mm)
Relative Humidity Range: 8% to 80%, RH ± 3%
Temperature Range: -10 to 65°C (± 1°C) / 14 to 149°F, (± 1.8°F)
Operating Humidity: 10% to 95%
Operating Temperature: 0°C to 45°C (32°F to 113°F)
Storage Temperature: -22°F to 158°F (-30°C to 70°C)
Waterproofing: IP65 rating
Max Current Consumption: 5mW
Battery Type: 1/2 AA ER14250 3.6V
Battery Life: 3 years
Weight: 42g
Warranty: 1-Year Limited
