Shop Aeotec Nano Switch with Z-Wave Plus & Power Metering
The Ezlo Z Wave Aeotec Nano Switch With Power Metering allows you to automate, schedule, and manually control any of your home’s wall switches or power outlets using Z-Wave gateways, hubs, and apps. As well as its standard on/off control and automation, this edition offers accurate energy consumption monitoring, allowing you to track and reduce your electricity spending. This innovative nano switch seamlessly integrates with your Z-Wave smart home system, transforming any standard switch or outlet into a remotely controlled and energy-saving powerhouse. The Aeotec Nano Switch features built-in power metering, allowing you to track your energy consumption and identify areas for potential reduction. Exceptional features of this Z Wave Nano Switch are:
Easy to Install: No need for extensive electrical work. The Aeotec Nano Switch boasts a user-friendly design that can be installed behind existing switches or outlets in minutes.
Z-Wave Plus Compatibility: Enjoy a reliable and dependable connection. This Z-Wave Plus nano switch utilizes Z-Wave Plus technology, offering enhanced range and improved communication with your smart home hub.
Invest in intelligence and efficiency with the Aeotec Nano Switch with Z-Wave Plus & Power Metering. This compact and versatile device empowers you to control your home remotely, automate routines, and track your energy consumption – all within a user-friendly Z-Wave ecosystem.
