Ezlo
2GIG Bypassable Door Window Contact 345 MHz
Regular price $25
Regular price $25 Sale price
Low stock
The 2GIG Bypassable Door Window Contact 345 MHz is designed for use on doors that may need to be temporarily bypassed to serve as an entry and exit path to an armed zone.
There is a discreetly hidden push-button integrated into the top of the case that allows a user to activate the bypass feature—to open and close the door once without having to disarm the alarm panel. An integrated LED indicates to the user, the state and status of the bypass feature. For higher security, the bypass push button can be disabled and the contact can be used as a micro-sized door window contact without the local bypass feature. A message is sent when the magnet is moved away from the Magnetic Door contact, and another message is sent when the 2GIG Bypassable Door Window Contact 345 MHz is replaced near the contact again Ezlo remote. Its Magnetic Door Contact communicates with a control panel at a 345 MHz frequency. 2GIG Bypassable Door Window Contact 345 MHz The contact is equipped with a cover tamper to notify the user if the device has been tampered with by Shop Ezlo.
Compatible with:
Shop 2GIG Bypassable Door Window Contact 345 MHz Ezlo
Regular price $25
