16A Tuya Zigbee 3.0 Mini Smart DIY Switch 1 Way Control Smart Home Relay Automation Breaker Works With Alexa Google Home Yandex
Regular price $4.28
Regular price $4.28 Sale price
Shop 16A Tuya ZigBee 3.0 Mini Smart DIY Switch With Take Control Anytime, Anywhere
The 16A Tuya ZigBee 3.0 Mini Smart DIY Switch is a compact and efficient solution designed to transform your traditional home appliances into smart devices. This Zigbee Mini Smart Switch supports both 1-way and 2-way control, allowing seamless integration into various electrical setups.
By connecting this switch to a compatible ZigBee gateway, you can remotely manage your devices through the Tuya Smart or Smart Life app, providing convenient control from anywhere.
  • High Compatibility: Works with major voice assistants like Alexa and Google Home, enabling effortless voice commands to control your appliances.
  • Compact Design: Measuring approximately 41x41x20mm, this mini switch fits easily into standard mounting boxes, making it ideal for DIY installations without extensive modifications.
  • Two-Way Control Support: Allows for physical two-way control, meaning you can operate your lights or devices both via the app and traditional switches, maintaining familiar manual controls.
  • Remote Access: Through the Remote Power Switch functionality, monitor and control your home appliances from anywhere using the mobile app, ensuring peace of mind and energy efficiency.
  • Scheduling and Timers: Set timers or schedules to automate your devices, enhancing convenience and reducing unnecessary power consumption.
The 1-Way Smart Switch is perfect for upgrading your home's lighting system, fans, or other appliances to smart functionality. With its high 16A load capacity, it can handle devices with significant power requirements, making it versatile for various applications. The ability to set schedules and remotely control devices contributes to energy savings and adds a layer of security by simulating presence when you're away.
Installation and Integration
Designed for easy installation, this switch can be retrofitted into existing electrical systems without the need for extensive rewiring. Its compatibility with ZigBee 3.0 ensures stable and secure communication within your smart home network. By integrating this switch, you can create a cohesive and responsive smart home environment, linking it with other devices to establish customized automation scenarios.
Regular price $4.28
