1-5M USB Zigbee 3.0 RGB Neon LED Strip Lights Tuya Zigbee Waterproof Dimmable Flexible Tape Kitchen Cabinet TV Room Night Light
Regular price $20.75
Regular price $20.75 Sale price
Low stock
  • Luminous Flux: 2000-82000
  • Hign-concerned Chemical: None
  • Is Smart Device: YES
  • Power Generation: SWITCH
  • Model Number: 2835
  • LED Chip Model: YSR-CGB-RGB
  • Average Life (hrs): 50000h
  • Certification: CCC
  • Power Source: DC
  • Origin: Mainland China
  • Strip type: SMD
  • Power Consumption (W/m): 11.52W/m
  • Occasion: LIVING ROOM
  • Specifications (light beads / m): 120
  • Item Type: Strip
  • Brand Name: YSRSAI
  • Voltage: 5V
  • LEDs Number/M: 120
  • LED Chip Brand: sharp
  • Waterproof: Yes
  • Color Temp(K): RGB
  • TYPE: USB RGB Neon Strip
  • Size: 1M,2M,3M,4M,5M
  • Output Voltage: 5V
  • Type: RGB Neon String Light
  • Installation Area: Indoor & Outdoor
  • Feature 1: Work with Alexa Google
  • Feature 2: APP/Voice Controller
  • Feature 3: Led Lights for decoration
  • Feature 4: Led night Light
  • Feature 5: Christmas Lghts
  • Occasion: kitchen, cupboard, living room, bedroom, stairs
  • Feature: Need work with zigbee gateway
  • Feature 6: Work with Smartthing
Note:
1, the controller is zigbee,need work with zigbee gateway,like tuya zigbee,Smartthings.
2, if you connect 4M 5M,suggest use 5V 2A power.
3, Some customer ask the RGB have white light ? RGB all have no Pure white color.
Neon light is an art at night, and neon light design is more soft, dynamic and gorgeous. The neon lamp uses a special switch to control its light and shade effect. The LED light source has high luminous efficiency, low power consumption, long service life, strong safety and reliability, and is conducive to environmental protection.
Features:
怐APP Control怑 Even you are not at home, you can control your smart led strip on/off with your phone via Tuya or Smart Life App. Easily set schedule for your smart led strip. Customize your home light system, like setting lights to come on at dusk or turn off at sunrise. You can create a group for all of your smart led strip and control them all with just one command. Works with 2.4GHz Wi-Fi network.
怐Millions Color Changing怑Express yourself and make your space more creative with Smart led strip. Choose from 16 million colors and shades of white to instantly change the look and atmosphere of your room. Control remotely with your smart device, create customized scenes and unleash your creativity. Meet your party, read, leisure light.
怐Energy Saving&Wide Usage怑With LED technology, Save your electricity charge with newest lighting technology. This bulb can be used on anywhere you need colorful light such as home indoor lighting, hotel, meeting room, museum, restaurants, bar
RGB Led Specification:
Type: Soft Flexible RGB LED Neon Rope lights
Input Voltage:DC 5V
Waterproof: Waterproof(IP65)
Beam Angle:180 degrees
Strips Width: 6MM*12MM
LED QTY: 120LEDs/M
LED Type: SMD 5050
Strip Length: 1M / 2M / 3M / 4M / 5M
Light Color: RGB
Control by: zigbee Control,need work with zigbee gateway.
