1 2 3 4 Gang Tuya Zigbee Smart Light 2-Way Control Touch Wall Switch With/No Neutral Wire Smart Life via Alexa Google Home Alice
Regular price $27.31
Regular price $0 $27.31 Sale price
NOT:When using No Neutral Wiring, please make sure to connect the capacitor to the L1 light
HIGHLIGHT :
【TWO wiring methods】Support Need Neutral Wiring and No Neutral Wiring.Support No Neutral Wiring,but you need a capacitor when you use No Neutral Wiring.
【3 control methods】APP control Voice control Switch touch control.
【Two indicator colors】Soft lighting,on:redlight/off:bluelight,You can turn on or off the indicator light in the app.
【APP remote control】 Tuya or smart life APP can be used to remotely control the switch on and off. You can see the open or closed state of the switches from the APP when you are away.
【Link with other smart devices】It can be connected to other smart devices to realize a convenient smart life together. A home mode can be created and linked with other smart devices to automatically open the light as soon as you go home.
【Support voice speaker control】The switch is compatible with Alexa and Google Home Assistant, allowing you to use the voice control smart switch to turn on/off.
【Timing】The smart switch is automatically turned on and off at a given time through the timer function. Choose the time you want to wake up, automatically open the light, so you can easily enter the day; choose the time you want to close the light.
【Share】The control switch can be shared with family members.
【SENSITIVE TOUCH CONTROL】Tempered glass touch screen of this smart switch is sensitive to the touch of control, premium durable glass material provides up to 20 million touch figures through our rigorous testing. It is water-proof,Damp-Proof, Resists Scratches.
【 Support 2-Ways Control】2-Ways/Multi Control Assosiation Make the device can be controlled by two switches at the same time.Other switches only need to connect the N and L wires
Set up multi control associations through the APP to achieve synchronization or mutual control of switches or any path.
【Work As a Zigbee Signal Repeater】Works As AS ignal Transfer Station Switch can work as a zigbee signal repeater
【Waterproof】Suitable for humid environment,such as lavatory,bathroom,etc.
【ZigBee Version】Tuya ZigBee Gateway/Hub is required.
SPECIFICATION :
1.Size:01 US:120*72*34mm;02 EU:86*86*35mm;03 :120*120*35mm
2.Rated voltage:100-240V,50-60HzRF
3.output:MAX2500W(1000W/gang)
5. Tempered glass
6. ZigBee satndard:ZigBee 3.0
7. The weak luminous design at night does not disturb the rest
8. Each switch is different, you can distinguish different lights
9.App: smart life, TUYA
10. Touch tempered ZIGBEE switch
11. Anti-drop, anti-scratch, wet hands
Package Included:
1*switch, 1* manual,1* mounting screw package,1*capatitor
Supports multiple wiring methods:
