Frankever Smart Dimmer
$ 9.95
12 months remote access free with Ezlo
$ 9.95
The integrated, precision touch dimer gives you total control over lighting intensity, effortlessly setting the perfect mood. Manage dynamic dimming from the sleek panel, remotely via the MiOS app, or through convenient voice commands, all with or without an active cloud connection.
Input voltage:
AC 100-240V
Rated Frequency:
50/60Hz
Wireless standard:
WiFi 2.4G
Max. Current:
10A
WiFi:
IEEE 802.11 b/g/n
Incandescent Bulbs 400W
Bulb Dimmable LED Max: 150W
App support:
Android (MiOS, Home Assistant)
CFL Lights max:
150W
Important safety warning
High Voltage Device: Risk of Electric Shock This device operates on AC 100-240V electricity. Installation requires direct interaction with your home's electrical wiring.
Turn Off Power: Always switch off the main power at your circuit breaker before attempting installation.
Professional Recommended: If you are unfamiliar with electrical diagrams, line/load identification, or safety protocols, do not attempt to install this device yourself. Please hire a licensed electrician to ensure a safe and code-compliant installation.
Control Your Lights Forever: Local-First & Open-Source
Upgrade to the Frankever In-Wall Switch for lightning-fast response times and smart control that prioritizes your privacy.
Local Device Speed
Processes commands directly on the device to eliminate lag. Continues working during internet outages.
Open-Source Freedom
Built on the EzloPi platform, giving you transparent, customizable control
Privacy Focused
Operates locally, on your Home Assistant, or on the Ezlo US-based Cloud, ensuring your data never leaves US soil.
Cloud Independent
Designed to work with any cloud, ensuring your home automation is never disabled by server downtime.
Atmosphere Control,
With or Without the Cloud
The integrated, precision touch slider gives you total control over lighting intensity, effortlessly setting the perfect mood. Manage dynamic dimming from the sleek panel, remotely via the MiOS app, or through convenient voice commands, all with or without an active cloud connection.
Transform room ambiance effortlessly—from warm hues for relaxation to vibrant colors for entertainment
True Local Operation
Maximum speed and privacy with zero cloud dependency.
US-Based Cloud Operation
Secure remote access hosted entirely on compliant US-based servers when using MiOS
Home Assistant Ready
Native integration available via HACS. Enjoy seamless BLE onboarding from your phone to configure your devices with absolutely no coding required.
Automated Schedules
Custom timers and routines that execute locally, even without internet.
Remote Control
Control your lights from anywhere, not just from your living room.
Advanced Automation
Complex local routines via seamless MiOS and EzloPi integration.
Effortless Home Assistant
Take full advantage of the native EzloPi Home Assistant Integration, available directly via HACS. We've made local control easier than ever:
Zero Coding Required
Build your perfect smart home ecosystem and configure devices without any programming knowledge.
Local Control
All device control is handled locally, ensuring fast response times and privacy.
BLE Onboarding
Easily onboard and configure devices using your iPhone or Android device.
Frankever Smart Switch
Smart lighting that adapts to your schedule
Ensure your home stays bright even on days that are gloomy and rainy. Adapting to weather conditions is possible for Frankever Smart Switch with built-in scripting, which allows it to turn on lights earlier when it's overcast and gradually increase brightness as the day transitions into evening.
Advanced automation Ezlo MeshBots
Smart night lighting
Frankever Smart Switch can provide soft light during the night by reducing brightness after a set time in Night Mode. The full brightness stays active until the light is turned off, so it won't get in the way of late evenings or gatherings.
Powered by the Open-Source EzloPi platform
The Open-Source, US-Secure Foundation for Your Smart Home
Choose ultimate control and peace of mind with EzloPi. Our Wi-Fi devices offer secure, local operation, a US-based cloud, and are built to be Home Assistant Ready, ensuring a future-proof, private, and reliable smart home experience.
Frequently Asked Questions
Orchestrate your home with ease. With automation, you can shut off the lights from your car or control your thermostats from anywhere in the world. The only limitation is your own imagination.
Frequently Bought Together
With over 10 years of experience, Ezlo has developed a platform trusted by dealers, builders, utilities, and real estate companies across the globe. Our technology processes 1.2+ billion smart events each month, powering over 1 million connected devices—all designed to work seamlessly together.
Trusted Around the World
Ezlo's solutions are used in 60+ countries and trusted by some of the biggest global brands. Our international team works every day to deliver reliable, scalable technology that transforms how people interact with their spaces.
What's New at Ezlo
