Shop Enbrighten Z-Wave Plus In-Wall Smart Paddle Dimmer, 700 Series (White/Almond Color)
Upgrade your home lighting with the Enbrighten Z-Wave Plus In-Wall Smart Paddle Dimmer, 700 Series. Designed with the latest 700 series Z-Wave Plus technology, this Z-Wave Paddle Dimmer provides superior speed and reliable communication with your smart home hub, including compatibility with Ezlo, Alexa, Google Assistant, and other leading smart home systems.
With its easy-to-use Smart Paddle Dimmer design, you can effortlessly adjust your lighting to create the perfect ambiance for any space. The dimmer supports full-range dimming, allowing you to customize the brightness levels of your lights to suit different activities, from cozy movie nights to bright task lighting.
The In-Wall Smart Paddle Dimmer offers a sleek and seamless installation that fits into standard wall boxes, ensuring a professional, clean look. With its dual white and almond color options, this dimmer will blend beautifully with your home decor. Not only does it enhance the look of your home, but it also provides energy-saving benefits by allowing you to lower the brightness and power consumption of your lights.
Key Features:
- Z-Wave Paddle Dimmer: Enhanced communication with the latest 700 series Z-Wave Plus technology for faster, more reliable performance.
- Smart Paddle Dimmer: Provides easy touch control for dimming and lighting adjustment, improving comfort and convenience.
- In-Wall Smart Paddle Dimmer: Sleek and professional in-wall installation with a clean finish.
- Customizable Lighting: Full-range dimming to set the perfect mood in any room.
- Wide Compatibility: Works with Ezlo, Alexa, Google Assistant, and other popular smart home hubs.
- Energy Efficient: Helps save energy by adjusting lighting levels to suit your needs.
Benefits:
- Seamless integration with your existing smart home network.
- Stylish design with white/almond options to suit any decor.
- Enjoy greater control over lighting, saving energy while enhancing comfort.
- Quick and simple installation with professional results.
Product Specs:
Manufacturer Part #: | 58438 |
UPC: | 030878584388 |
Color: | White |
Size: | 1-Gang |
Power: | 120 VAC, 60 Hz |
Protocol: | Z-Wave Plus |
Frequency: | 908.4/916 MHz |
Maximum Loads: | 600W, 2-gang 500W or 3-gang 400W incandescent, 360W/3A Dimmable CFL/LED |
Environmental Conditions: | For indoor use only |
Operating Temperature Range: | 32 to 104° F (0 to 40° C) |
Approvals: | FCC, IC |
Warranty: | 5-Year Limited |
Lucas (verified owner) –
Good service.
Nolan (verified owner) –
Very fast delivery.
Paul (verified owner) –
Good quality.
Avery (verified owner) –
Good quality.
Jackson (verified owner) –
Good quality.
