Cat5e Cable, Direct Burial, Gel-Filled, 1,000 Ft.
(5.00)5 Reviews
In Stock
$215.28
SKU: WRCAT5EDBG10B
Looking for a reliable and durable Cat5e cable for your networking needs? Look no further than this Direct Burial Gel-Filled Cat5e Cable, available in a length of 1,000 feet. Designed to withstand harsh outdoor environments, this cable is perfect for burying directly in the ground or running through conduit. The gel-filled construction provides protection against moisture and other environmental factors, ensuring a long-lasting and stable connection. With high-speed data transfer capabilities and compatibility with a variety of applications, this Cat5e cable is a must-have for any outdoor networking project. Order yours today and get ready to take your network to the next level.
Manufacturer Part #: CAT5E-DB-GEL
Sheath Printing: STRUCTURED CABLE PRODUCTS – – – P/N CAT5E-DB-GEL – – – CAT5E DIRECT BURIAL ENHANCED 350 MHz 4 PR 24 AWG SOLID UTP GEL FILLED LLDPE VERIFIED TO ANSI/TIA-568-C.2 CE EU RoHS EC ZONE/DEVICE A B C D E 0 1 2 3 4 5 6 7 8 9 XXXX FEET MM/YY
Category: U/UTP GEL CAT5e-4P-PE
Test Standard: ISO/IEC11801, TIA-568-C.2 YD/T1019
Conductor Material: SOLID-Bare Copper
Conductor Nom. O.D.: 0.5 mm, ±0.005 mm
Insulation Material: HDPE
Insulation Diameter: 1.00 mm ± 0.03 mm
Insulation Color: Blue: White-Blue, Orange: White-Orange, Green: White-Green, Brown: White-Brown
Rip-Cord: Yes
Drain Wire: No
Sheath Thickness: 0.55 ±0.05 mm
Sheath External O.D.: 5.5 mm ± 0.5 mm
U.V Stability: U.V Resistant
Sheath Material: LLDPE (complies RoHS)
Sheath Color: Black
Surface Printing: Letter Height: 3.0 mm ±0.3mm, Color: White, Print Error / Space: =10.0 Mpa
Elongation: >=350 percent
Aging Period: 100°C x 24hrs x 10d
After Aging Elongation: >=300 percent
Cold Bend Test: -20°C 4 hours; No Cracking
Electrical Characteristics (20°C): 1.0-100.0MHz, Characteristic Impedance: 100 ohms ±15 ohms
Delay Skew: <=45 ns/100m
DC Resistance Max: 9.5 ohms/100m
DC Conductor Resistance Unbalance Max: 5.0 percent
Customers Reviews
(5)
  1. Mateo (verified owner)
    Very fast delivery.
    1 product
  2. Aiden (verified owner)
    Good quality.
    1 product
  3. Riley (verified owner)
    The product is firmly packed.
    1 product
  4. Henry (verified owner)
    Good service.
    1 product
  5. Patrick (verified owner)
    Good quality.
    1 product
Back to Top
chatsimple
