The Bellman & Symfon Visit Charger for Vibrating Pager Receiver is the perfect accessory to ensure that your pager receiver is always charged and ready to go. This compact and lightweight charger is designed to work specifically with the Bellman & Symfon Visit Vibrating Pager Receiver, providing a reliable and convenient charging solution.
Simply plug the charger into any standard electrical outlet and connect your pager receiver to the charging dock, and in no time your device will be fully charged and ready to use. With its sleek and modern design, this charger is ideal for use at home or on the go, making it an essential accessory for anyone who relies on their Bellman & Symfon Visit Vibrating Pager Receiver. the specification of Bellman & Symfon Visit Charger for Vibrating Pager
Mains power: | 6 V DC / 800 mA with built-in power supply unit |
Back-up battery: | Internal NiMh batteries. The internal back-up batteries must be changed at a service workshop. |
Charging the back-up battery: | Via the power supply unit. Discharged back-up batteries will take at least 24 hours to charge. The normal charging time is approximately 6 hours. |
Vibrator power: | 2 to 4 V DC, BE9086 should be connected to vibrator output B. |
Dimensions: | 78(W) x 88(H) x 43(D) mm |
Weight: | With battery: 385 grams |
Color: | White |
Flex length: | 1.7 meters |
Usage: | For indoor use only |
Hayden (verified owner) –
Good quality.
Lucas (verified owner) –
Good service.
Leo (verified owner) –
Very well worth the money.
Ryan (verified owner) –
Good quality.
Robert (verified owner) –
Good service.
