Shop Bellman & Symfon Domino Classic Listening System with Neckloop
The Domino Classic Listening System by Bellman & Symfon is an innovative and user-friendly solution for individuals experiencing hearing loss. This advanced system consists of a wireless receiver worn around the neck, coupled with a neckloop that transmits crystal-clear sound directly to your hearing aid or cochlear implant. With a transmission range of up to 100 feet, the Classic Listening System with Neckloop allows you to enjoy enhanced audio clarity while moving freely around your home or office.
Key Features:
- Wireless Connectivity: The Domino Classic Listening System offers a powerful wireless receiver that seamlessly connects with your hearing aid or cochlear implant via the neckloop, ensuring you receive clear and amplified sound even at a distance.
- Built-in Microphone: The system features a built-in microphone that can amplify conversations, phone calls, or any other important sounds, making it easier to engage in social interactions and daily activities.
- Adjustable Volume Control: With multiple levels of volume control, the Classic Listening System with Neckloop allows you to tailor the sound to your specific hearing needs, providing a personalized listening experience.
- Compatibility: Designed to be compatible with most hearing aids and cochlear implants, this versatile system can be used in various settings, from watching TV to attending meetings, ensuring you never miss out on important moments.
Convenience and Portability:
The Domino Classic Listening System is compact and lightweight, making it easy to carry and use wherever you go. Its wireless design eliminates the hassle of tangled cords, and its user-friendly controls make it accessible for all ages. Whether at home, in the office, or on the go, this Classic Listening System with Neckloop is your ideal companion for maintaining a connected and engaged lifestyle.
Product Specs:
Dimensions: | 99 x 48 x 22 mm (HxWxD) |
Weight: | 74 grams (2.5 ounces) |
Color: | White/grey with silver-colored buttons |
Operating temperature: | 32 to 95 degrees F (0 to 35 degrees C) |
Relative humidity: | 5 to 95 percent (non-condensing) |
Regulatory requirements: | CE, FCC, RoHS, WEEE, C-Tick |
Power Supply | Battery power: Internal Lithium-Ion type, 617 mAh, type NTA2617 |
Operating time, fully charged: | 8 to 12 hours (standard battery) |
Transmitter charging time: | 2.5 hours (standard battery) |
Receiver charging time: | 2.5 hours (standard battery) |
Input Signals | Microphone: Internal electret condenser type (omnidirectional) External sound source input: 2.5 mm stereo jack plug (0 dBV max input signal). Automatically selects Aux. input or External mic. |
Output Signals | Headphone socket: 3.5 mm stereo jack plug Output power: 100 mW at 16 ohm load Distortion: BE9122 Headphones 0.6 percent THD, BE9124 Ear Phones 0.08 percent THD Dynamic range: 95 dB SNR (electrical) Frequency range: 40 to 10,000 Hz (electrical) Max output level, saturation: BE9122 Headphones: 124.3 dB SPL / BE2270: 124.3 dB SPL (at 2.5 kHz) BE9124 Ear Phones: 132.0 dB SPL / BE2270: 130.5 dB SPL (at 5 kHz) BE9125 Stetoclips: 133.7 dB SPL / BE2270: 133.6 dB SPL (at 1 kHz) Full on gain (60 dB SPL input signal at 1 kHz): BE9122 Headphones: 42.5 dB / BE2270: 44.0 dB BE9124 Ear Phones: 55.0 dB / BE2270: 57.5 dB BE9125 Stetoclips: 58.2 dB / BE2270: 64.2 dB Full on gain (60 dB SPL input signal, HFA): BE9122 Headphones: 46.5 dB / BE2270: 49.0 dB BE9124 Ear Phones: 51.5 dB / BE2270: 56.0 dB BE9125 Stetoclips: 52.0 dB / BE2270: 59.4 dB |
Radio Function | Digital radio technology: 2.4 GHz frequency band, 3 channels Co-exists with other equipment Automatic channel selection 128 bits encryption Topology: Point-to-point or Point-to-multipoint Diversity: 2 antennas for reception, one antenna for transmission (Rx + Rx/Tx) Transmitting output power: Max. 25 mW Operating range radio: Up to 25 meters indoors clear line of sight, up to 100 meters outdoors clear line of sight. Walls, concrete, and metal reduce the range. |
Neckloop | Neck strap length: 70 cm Cable length: 90 cm Connector: 3.5 mm teleplug (stereo), 90-degree angle Color: Black Weight: 30 g Size: 3.5 x 4 x 1 cm (WxHxD) Impedance: 2 x 5 ohm Output: 100 mA/m at 10 cm distance and 2 x 1.0 Vrms incoming signal |
Richard (verified owner) –
Very well worth the money.
Robert (verified owner) –
Good quality.
Kai (verified owner) –
Good quality.
Anthony (verified owner) –
Good quality.
Zohar (verified owner) –
Good quality.
