{"product_id":"zigbee-4-gang-switch-scene-switches-6-gangs-interruptor-neutral-required-work-with-tuya-hub-alexa-google-home-voice","title":"Zigbee 4 Gang Switch Scene Switches 6 Gangs Interruptor Neutral Required Work with Tuya Hub Alexa Google Home Voice","description":"\u003cdiv\u003e\n\u003cdiv\u003e\u003cp\u003eZemismart Zigbee 4 gang Switch Scene Switches 6 Gangs Interruptor Neutral Required Work with Tuya Hub Alexa Google Home Voice\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eKindly Note:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- There are two types of 6-Gang switches in this link, one is a 4-Gang light switch plus 2-gang scene switches, and the other is a 6-Gang switch composed of two 3-Gang switch Module. If you have any questions, please consult Zemismart store customer service before placing an order.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e-This product requires a Tuya Zigbee hub or Smartthings hub enabled device to operate.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S57d4ca288e8f41b29db7f6c488de47972.jpg\"\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eZigbee 6 Gangs Wall Light Switch\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e-Tuya APP 【Multi-Control Association Function】\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eNew Function for our zigbee switch is Multi-Control Association, it allows to control one light by multiple switches. This function is more convenient for the zigbee switch, can control one light by 2 switches or multiple switches on Tuya.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- High Quality Physical Push Button Design:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eHigh-quality and luxury design with Big physical button for push control. You can install it in your bedroom or living room. If the zigbee central control is far away, and you can install a zigbee switch in the middle, it will extend the signal of the zigbee central control by a few meters.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- Tuya Zigbee Smart Wall Light Switch:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eThis Zigbee smart light switch is a perfect alternative option for traditional lighting system. It is designed in the size of US standard wall mount light switch, comes with all accessories you need to replace an existing wall switch.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- Voice \u0026amp; Timer Control:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eSmart Light Switch for Amazon Alexa and Google Home, activates the on\/off button with voice commands, making life easier. Set up a schedule or timer on\/off your lights on night, and then your will never go back to a dark house when you go back home after working.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- Remote Control:\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eSmart Home Light Switches can be controlled remotely using your phone, and devices connected with switches can work independently. Even if you are not at home, you can use the mobile app to remotely control the device from anywhere and control the lights on\/off at any time.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0346d403da704d8abf0e528c1ce148f7h.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sd29bc54f7bcc42288c0a4ef51904bff21.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2083bbe029aa4320b943a66cfded053aL.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S50e027756b4649338480548a34008089X.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Saaf1e5cb3297443faf0e5215b7926f0aS.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0adc22603a3c4dada510c4ae528002cae.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S582514a0aaac4d1aa980b54680805f64n.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9e602a11046a4c1cb55918d99a9f7f48S.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S93ca5f9f06bb406fb601432d493eadfdZ.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sd65057328cbb426d845e9488c16b8555o.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0c58645809804d5795803b75ac08f209Q.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S95d18ed3a6604d2a830f46f158f02acaH.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003eZigbee 4 Gang Switch with 2 Gang Scene Switch\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- Neutral Wire Required, work with a tuya zigbee hub(need to buy separately.)\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- 4 Gang light switch + 2 Gang scene switch, you can set up the task in the scene switch, just push the button.\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- Voice control by Alexa or Google Home\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\u003cp\u003e- Tuya\/Smart Life APP remote control\u003c\/p\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S57d4ca288e8f41b29db7f6c488de47972.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Se10a51f4c2eb46daa3d9277d9e089065l.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sd4d85cc236fb409db54717723c8089d0P.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S92efcd13c9d84c0aa302e689f37b5b5dR.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8137f5529aaa4543a8e0669d591375d6z.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sb0c47849307541a5849e71ebca78e50fR.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S6cf1f15415fd4393b1aeab9a1962b92fD.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S4f386716f860494b970b0918672a58bb6.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9adc244ed53b48168f8303c26d50e7abd.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9bc80d190b1d40deb3a0f473359df4b3Q.jpg\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sfb588776c0384b51ab087bd1fae00f72c.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S9cf117015f0a41169dac38f86ab831d1v.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sacefe39f51f3491e88bf6cd2634c47bb1.jpg\"\u003e\n\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Ezlo - Property Empowered","offers":[{"title":"White 6 Gangs","offer_id":52044065046821,"sku":"ceadd3dd-751b-42c2-87dc-3227f44181f2","price":128.93,"currency_code":"USD","in_stock":true},{"title":"Black 6 Gangs","offer_id":52044065145125,"sku":"f2af7586-cb98-4d87-8b05-ae3d51afccaf","price":134.52,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S9faef192778b44f592ddd6c33b53b0c4J.webp?v=1772443380","url":"https:\/\/shop.ezlo.com\/products\/zigbee-4-gang-switch-scene-switches-6-gangs-interruptor-neutral-required-work-with-tuya-hub-alexa-google-home-voice","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
