{"product_id":"wifi-zigbee-smart-2-zone-watering-timer-garden-automatic-irrigation-system-drip-sprinkler-controller-valve-smart-life-tuya","title":"ZIGBEE Smart 2 Zone Watering Timer Garden Automatic Irrigation System Drip Sprinkler Controller Valve Smart Life Tuya","description":"\u003cdiv\u003e\n\u003cdiv\u003e\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eTYPE：WIFI Watering Timer\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003eMain Funtion:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eThis kit including one wifi water timer and one wifi gateway.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eone gateway can pair with max 32 water timers.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eBluetooth communication with wifi gateway and water timer.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eSet and check irrigation schedule through smart phone APP.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eManually rain delay function.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003emanually watering.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eNormal timing, cyclic timing for watering. \u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ebuild-in filter.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eTechnical Parameter:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e3\/4 inch BSP or NH inlet Two 3\/4 inch BSP or NH outlet thread.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWorking pressure:7.25-116 psi\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eMax flow:5L\/min-35L\/min \u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eIP55 water proof\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWorking temperature 0-50 Celsius\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eBattery life 6 months\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ewifi timer power by 2 AA batteries.wifi gaterway power by AC power\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eirrigation mode:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ewatering frequency:At least one minute\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ewatering times:No limit\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ewatering duration:from 1 min to 24h\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eCyclic mode:\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eworking time:Unlimited\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003ewatering time:1 min to 24h\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003einterval timer:1 min to 24h\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eProduct advantages\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1. The product setting is simple. Compared with the traditional water valve, the product setting and operation are simple\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e2. The timing program can continue to run without connecting to the gateway or mobile phone\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e3. According to the local weather, the water valve automatically delays watering (requires a gateway), and the weather delay can also be set manually\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e4. The timing program is flexible, customers can set multiple sets of timings according to the use scene, up to 15 sets\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e5. Connect the gateway, cooperate with the humidity sensor, can do scene linkage\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e6. The product can be used flexibly, it can be used with a gateway or a single water valve\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e7. The week mode can be selected at regular time, and the use is more user-friendly\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e8. Cycle timing, can run in a period of time\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e9. The running time is as small as 1 minute, which is suitable for drip irrigation and spraying scenes.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e10. The shell is made of UV resistant material, which will not deform or crack under high temperature\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e11. The magnetic valve has good sealing performance, no water leakage, and stable performance\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc7d5b5066e0d452da2ef91358205ec63X.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S0bbdccac0ffd4ed8bc2e30ac79f848a2q.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Secbd6d74f16c46e9ac533b984318bb3e3.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sbae4a54bfe1d431e802eb6f5de2c3cecM.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S2f77f27128c74946a1f91705b0f77a15v.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sf04e7342840944f4874f7dc614f569700.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sacbcb04b40de435eb680e7fb74262f72K.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S7e739d37372f482ba79d48f39d2c3ed85.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sdedfa45085e94f698d099bbe411fbbe3O.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sf1b1d1e419524148960af1c278382c10D.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S92c32b0aa80342efb7fb752ab0492c12S.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S482acd0a53e64cba88e53942e79047aca.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8279784e4e6847a6a408c6d8fbde7eb50.jpg\"\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003c\/div\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Ezlo - Property Empowered","offers":[{"title":"1Pcs-Valve (193_4165777) \/ Zigbee (193_4165777)","offer_id":52098838364453,"sku":"0c880de8-06d3-46b5-9bb5-3701681ba1d4","price":94.2,"currency_code":"USD","in_stock":true},{"title":"2Pcs-Valve (496_4165777) \/ Zigbee (496_4165777)","offer_id":52098838397221,"sku":"0d96278c-0a60-441b-89d3-12e604e5237d","price":188.3,"currency_code":"USD","in_stock":true},{"title":"3Pcs-Valve (350853_4165777) \/ Zigbee (350853_4165777)","offer_id":52098838429989,"sku":"5837743c-4885-4368-9ac4-a04fc333b2f0","price":279.64,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/Sc11cda827c6c42359025171134d1aff0w.webp?v=1774016010","url":"https:\/\/shop.ezlo.com\/products\/wifi-zigbee-smart-2-zone-watering-timer-garden-automatic-irrigation-system-drip-sprinkler-controller-valve-smart-life-tuya","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
