{"product_id":"tuya-zigbee-leak-sensor-water-leakage-detector-leakage-sensor-water-sensor-prevent-water-leakage-for-smart-home-smartlife","title":"Tuya Zigbee Leak Sensor Water Leakage Detector Leakage Sensor Water Sensor Prevent Water Leakage for Smart Home Smartlife","description":"\u003cdiv\u003e\n\u003cdiv\u003e\n\u003ch1\u003eProduct Features:\u003c\/h1\u003e\n\u003cp\u003e\u003cstrong\u003e1. Water poof, water leak detection\u003cbr\u003e\u003c\/strong\u003eThe sensor can detect whether there are water leakage at the installation location. If this is found, the information will be pushed to the phone immediately.\u003cbr\u003e\u003cstrong\u003e2. Easy to Install\u003cbr\u003e\u003c\/strong\u003eThe installation of the sensor is very simple, you can use adhesive taps to install at the location you need to install, please note that the installation location should be connected to the Zigbee Hub.\u003cbr\u003e\u003cstrong\u003e3. Use Zigbee, Tuya Zigbee hub is required \u003cbr\u003e\u003c\/strong\u003eThe sensor uses Zigbee to communicate with the server for data. So it won't be disturbed by other WiFi devices. Its communication link is more stable and faster.\u003cbr\u003e\u003cstrong\u003e4. Remote Monitoring\u003cbr\u003e\u003c\/strong\u003eThe alarm information and records of the sensors are all stored on the server. This design allows us to monitor whether there is water in the home or office from any place through the smartphone. And can also share the control information of the device to others.\u003cbr\u003e\u003cstrong\u003e5. Low battery consumption\u003cbr\u003e\u003c\/strong\u003eThe power consumption of the sensor in standby mode is very small, and one CR2032 battery can be used for one year. And when it detects that the battery is low, it will remind you to replace the battery through the alarm message.\u003c\/p\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cspan\u003eNOTE: Do not support Zigbee2Mqtt\u003c\/span\u003e\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cspan\u003eNOTE: Do not support Other Zigbee Hub.\u003c\/span\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H57ab7417156a4bfe8eead520059d74fe3.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H3682d677281d4228a03420772378f7114.png\"\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003cp\u003e\u003cspan\u003eTuya Zigbee Hub Requested\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eThis door sensor doesn't work alone. It need to work with Tuya ZigBee hub to function\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H0350cd7e3f8b494d9ea56b844a32c614v.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003ch1\u003eProduct Parameter:\u003c\/h1\u003e\n\u003cp\u003eBattery: CR2032（included）\u003cbr\u003eWireless Type: Zigbee(Tuya Zigbee Hub Only)\u003cbr\u003eWorking Temperature: 0℃～40℃ (32℉ ～104℉ ）\u003cbr\u003eWorking Humidity: 20%～85% RH\u003cbr\u003eStorage Humidity: 0%～90% RH\u003cbr\u003eApp Support: Smart Life\u003cbr\u003eMaterial: ABS\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H35f438a6749e4dda8bca22a4f0db54521.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003ch1\u003e\u003cstrong\u003eWhere can I use it?\u003c\/strong\u003e\u003c\/h1\u003e\n\u003cp\u003eYou can install it in anywhere you worried about water leakage. For example: Kitchen, sink, bathroom, fish tank. Or you can use sensors to remind yourself that a container is full of water.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/He4209a5f880d4f46a0716c24ff000a25u.jpg\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003ch1\u003eWorking Principle\u003c\/h1\u003e\n\u003cp\u003eWhen the two feet of the detector was immersed by the water, the alert notifications will be pushed to your phone, be aware of water overflowing in time, reducing flooding risk.\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Hadf70427cc80416f9c13711ecc876a708.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\n\u003ch1\u003eAPP Remote Control\u003c\/h1\u003e\n\u003cp\u003eMobile APP control, connected to the network via Wi-Fi\/3G\/4G\/5G, Remote control at any time. After the sensor detects the leak, it immediately pushes a message to your mobile APP\u003c\/p\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H019a38baa3da45f0a37428d0f5f4f54at.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/H8fbcaa3f7f4740e49917000b6aecb05am.jpg\"\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cbr\u003e\u003c\/p\u003e\n\u003c\/div\u003e","brand":"Ezlo - Property Empowered","offers":[{"title":"1 Pcs","offer_id":52239838216485,"sku":"9d4f097a-aee3-453b-98e3-9b644069a48f","price":27.4,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/S17c89f294dfe4fe084d6da0ffb21036e3.webp?v=1776416589","url":"https:\/\/shop.ezlo.com\/products\/tuya-zigbee-leak-sensor-water-leakage-detector-leakage-sensor-water-sensor-prevent-water-leakage-for-smart-home-smartlife","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
