{"product_id":"tuya-smart-home-zigbee-temperature-humidity-sensor-led-backlight-smart-life-app-remote-work-with-alexa-google-assistant","title":"Tuya Smart Home Zigbee Temperature \u0026 Humidity Sensor LED Backlight Smart Life APP Remote Work with Alexa Google Assistant","description":"\u003cdiv\u003e\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eFeatures:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cbr\u003e\n\u003cspan\u003e1. High precision.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eThe sensor uses top suppliers. It can guarantee the high precision of the measurement data.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e2. Real-time monitoring and recording.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eThe sensor will report when the temperature and humidity changes very little. You can view the changes in the value on the APP or display screen.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eRecord the temperature and humidity changes on the APP, and use the graphics to show you.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e3. Backlight Supported\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eThe sensor has backlight, it make you browser the screen clear at night.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e4. Wide viewing angle\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eWe have carefully designed the viewing range of the LCD screen, compared to other types of similar products, our viewing angle is wider.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e5. Scene linkage\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eThe sensor can be used as the temperature and humidity data source of Tuya Smart, Smart Life, Amazon Alexa, Google Home. You can do many automated processes based on the data source.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e6. Temperature Unit Switch\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eThe sensor is designed with a temperature display conversion function of Celsius and Fahrenheit. You can choose the unit that needs to be displayed according to your needs.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e7. Third-party voice support.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eThe sensor supports Amazon Alexa, Google Home Asistant. You can check the current temperature and humidity by voice.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eProduct Parameter:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eZigBee Version:( Tuya ZigBee Hub is required)\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eNote: the ZigBee Version Sensor can't work alonely,it need Tuya ZigBee Gateway\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eto work together.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003ePower supply: Battery LR03-1.5V\/AAA*3 (not included)\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eBacklight: Supported\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eWireless: Zigbee 3.0(Tuya Zigbee hub Only)\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eTemperature Measure Range: -9.9℃-60℃\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eTemperature Accuracy: ±1\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eHumidity Measure Range: 0% RH~99% RH\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eHumidity Accuracy: ±5% RH\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cp\u003e\u003cbr\u003e\n \u003c\/p\u003e\n\n\u003cdiv\u003e\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Ac4582b49ad7f4aec9d7511cf1e523337G.png\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/A43f99391efe849a7bbab0bc5cdddd694a.png\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/A430609489e8a494a8942fed35530d3ecS.png\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Aa65b0d38ad0e4307a43ffcc9a21083f0A.png\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eNOTE:\u003c\/p\u003e\n\n\u003cp\u003eAbout Displaying\u003cbr\u003e\n\u003cbr\u003e\n1. The time format cannot be changed.\u003cbr\u003e\n2. The temperature unit can be switched.\u003cbr\u003e\n\u003cbr\u003e\nAbout Bluetooth Function\u003cbr\u003e\n\u003cbr\u003e\nBluetooth function is only useful during configuration. After configuration, the device will shut down the Bluetooth network.\u003cbr\u003e\n\u003cbr\u003e\nAbout the update frequency of temperature and humidity\u003cbr\u003e\n\u003cbr\u003e\n1. We used the trigger mechanism When the temperature or humidity change reaches the trigger condition, report the data immediately The fastest update frequency is two minutes. Generally, the data is updated once an hour\u003cbr\u003e\n2. The sensor cannot set the update frequency,\u003cbr\u003e\n3. The sensor cannot set alarm, and the alarm function is set on the APP\u003cbr\u003e\nIf you need to update data in real time, please purchase a USB powered version.\u003cbr\u003e\n\u003cbr\u003e\nAbout batteries\u003cbr\u003e\n\u003cbr\u003e\n1. Only LR03-1.5V alkaline battery can be used (1.2V rechargeable battery may cause the equipment to detect wrong voltage and report low voltage)\u003cbr\u003e\n2. Batteries of different models cannot be mixed\u003cbr\u003e\n3. Batteries of different brands cannot be mixed\u003cbr\u003e\n4. New and old batteries cannot be mixed\u003cbr\u003e\n5. Do not use inferior batteries\u003cbr\u003e\nOtherwise, 1. configuration failure, 2. battery consumption is too fast\u003cbr\u003e\nHow to obtain high-quality batteries or genuine batteries. Please buy them at regular supermarkets or chain stores over time\u003cbr\u003e\nNote: After the device configuration is completed, it needs to be placed in a position where the wireless signal is good, otherwise the power consumption of connecting to the network will increase, which will lead to fast battery consumption\u003cbr\u003e\n\u003cbr\u003e\nAbout Network Testing\u003cbr\u003e\n\u003cbr\u003e\nThe network will consume a lot of power\u003cbr\u003e\nTo ensure the service life of the battery, the sensor will stop using the network when it does not need to report data\u003cbr\u003e\nTherefore, it is meaningless to test the network signal of sensors in APP.\u003cbr\u003e\n\u003cbr\u003e\nError on temperature and humidity\u003cbr\u003e\n\u003cbr\u003e\n1. All temperature and humidity sensors will have certain errors, please note\u003cbr\u003e\nThe error of this sensor is ± 1 ℃ and the error of humidity is ± 5% RH\u003cbr\u003e\nAny value within this range is normal\u003cbr\u003e\n2. Sensor error and manufacturing process will lead to certain errors between products of the same model\u003cbr\u003e\n3. According to Newton's third law, the heat conduction takes a certain time.\u003cbr\u003e\nTherefore, our sensor needs 30 minutes to be consistent with the room temperature, and the measurement will be accurate.\u003cbr\u003e\n\u003cbr\u003e\n\u003cbr\u003e\nAbout Historical Curves\u003cbr\u003e\n\u003cbr\u003e\n1. The minimum granularity of historical data (daily chart) is 1 hour, and the minimum granularity of exported data is also 1 hour\u003cbr\u003e\n2. Days of historical data are stored for 7 days\u003cbr\u003e\n3. The value of historical data is the average value, that is, the average value in a minimum granularity time\u003cbr\u003e\n\u003cbr\u003e\nSupport for third-party smart speakers\u003cbr\u003e\n\u003cbr\u003e\n1. Because the third-party smart speakers (Google Home\/Amazon Alexa) do not have control panels corresponding to temperature and humidity sensors, the temperature and humidity may not be displayed normally on the third-party smart speakers' APP. But we have opened the voice query function.\u003cbr\u003e\nTherefore, the current temperature and humidity can be queried by voice\u003cbr\u003e\n2. Route or automatic process related to temperature and humidity cannot be established on the third-party smart speakers\u003cbr\u003e\n3. The device does not support Yandex Alice\u003cbr\u003e\n\u003cbr\u003e\nAbout Automation\u003cbr\u003e\nThe sensor uses the principle of Edge Triggered\u003cbr\u003e\nThat is, the action can only be triggered if the condition crosses the set condition\u003cbr\u003e\nFor example, when the automatic setting temperature is greater than 25 ℃, then turn on the air conditioner.\u003cbr\u003e\n1. When the temperature rises from below 25 ℃ to 25 ℃, the automatic process can trigger to start the air conditioner\u003cbr\u003e\n2. After the automatic process is set, the temperature is always above 25 ℃, and the air conditioner is not turned on.\u003cbr\u003e\n3. When the temperature drops to 25 ℃ and rises to above 25 ℃, the automatic process will be activated.\u003cbr\u003e\n\u003cbr\u003e\nFor example, when the automatic setting temperature is less than 20 ℃, turn on the air conditioner\u003cbr\u003e\n1. When the temperature drops from above 20 ℃ to 20 ℃, the automatic process can trigger to start the air conditioner\u003cbr\u003e\n2. After the automatic process is set, the temperature is always below 20 ℃, and the air conditioner is not turned on\u003cbr\u003e\n3. When the temperature rises to 20 ℃ and then drops to above 20 ℃, the automatic process will be activated.\u003c\/p\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cdiv\u003e \u003c\/div\u003e\n\n\u003cp\u003eAPP Remote Monitor\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eWhen the sensor is registered to the APP and connected to the Internet, you can monitor the temperature and humidity of the room in real time anywhere in the world.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/A54b0dd8c64664d04915f5233c00bf20dJ.png\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/A7e2b3da17b47451382199f8c596df512Q.png\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eBacklight Supported\u003c\/p\u003e\n\n\u003cp\u003e\u003cspan\u003eWhen you tuch the reset button once, the backlight will be triggered , and it will last for about 10 seconds.\u003c\/span\u003e\u003c\/p\u003e\n\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Acb240269180f4ddcb655c6ab7946c659u.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eAccurate Measurement\u003c\/p\u003e\n\n\u003cp\u003eNOTE:\u003cbr\u003e\nAfter configuration, it will take 30 minuters to be accurate.\u003c\/p\u003e\n\n\u003cdiv\u003e\n\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Ad4ca523d9a8f4d5399169c9b493e4c15p.png\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/A47461a9832004766a39428abecff1946F.png\"\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eVoice Query Supported\u003c\/p\u003e\n\n\u003cp\u003eThe Sensor work with Amazon Alexa and Google Home. You can check temperature and humidity by voice.\u003c\/p\u003e\n\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Acdc5b67193344f22b685d9e4c2686ea2x.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eApplication Scenarios\u003c\/p\u003e\n\n\u003cp\u003eYou can install the sensor wherever you need (WiFi connection network is required).\u003c\/p\u003e\n\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/A4de8a57a4a7a412089756e04150181a6Z.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eIntelligent Linkage\u003c\/p\u003e\n\n\u003cp\u003eIn the APP, you can make linkage settings by setting the temperature and humidity of the sensor as conditions. It will make your life more comfortable.\u003c\/p\u003e\n\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Ud6fdc5e34e6e4d6cba4e90454325640fj.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cdiv\u003e\n\u003cp\u003eAPP Pages\u003c\/p\u003e\n\n\u003cp\u003eThe page could get better.\u003c\/p\u003e\n\n\u003cdiv\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/U8b28387ef5084934819e4d27309ad1931.png\"\u003e\u003c\/div\u003e\n\u003c\/div\u003e\n\n\u003cp\u003e \u003c\/p\u003e\n\u003c\/div\u003e\n","brand":"Luckystar","offers":[{"title":"Zigbee Version","offer_id":52616553955621,"sku":"46868e2d-c93c-4eba-9f04-4fb5d1adde15","price":19.81,"currency_code":"USD","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/c1ce2e1912f2462341570fd2a5c1570c.jpg?v=1781856209","url":"https:\/\/shop.ezlo.com\/products\/tuya-smart-home-zigbee-temperature-humidity-sensor-led-backlight-smart-life-app-remote-work-with-alexa-google-assistant","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
