{"product_id":"tuya-smart-home-zigbee-door-sensor-alarm-window-door-on-off-detectors-security-protection-compatible-with-alexa-google-assistant","title":"Tuya Smart Home Zigbee Door Sensor Alarm Window Door ON\/OFF Detectors Security Protection Compatible with Alexa Google Assistant","description":"\u003cdiv\u003e\n\u003cdiv\u003e\u003cdiv\u003e\n\u003cdiv\u003e\u003cspan\u003e\u003cstrong\u003eNotice:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e1、This device only can work along with a Zigbee Geteway. You need to connect wifi with a zigbee gateway successfully before use such zigbee T\u0026amp;H sensor.\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e2、Turn on the device and smart speaker (Amazon Alexa or Google Home speaker) , they will be connected automatically; \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e3、The device is also compatible with eWeLink ZigBee Gateway Hub. If TUYA Smart is not available for the device, please connect it with the eWeLink ZigBee Gateway Hub. \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S1ec45f32ef1b4ec38c40514dcb9698ccO.jpg\"\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cbr\u003e\u003cspan\u003e\u003cspan\u003e\u003cstrong\u003eSpecifications:\u003c\/strong\u003e\u003c\/span\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eAPP Name: Tuya Smart or Smart Life\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eBattery type: AAA1.5V*2 (Not include battery in shipment)\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eInput Voltage: DC3V LR03\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eQuiescent Current: ≤10uA\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eAlarm Current: ≤160mA\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eLow Power Undervoltage: ≤2.7V\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eMagnetic Control Distance: ≥15mm\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWorking temperature: -10℃~50℃\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWorking Humidity: max 95%RH\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003eWireless Type: Zigbee\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003eZigBee Gateway Hub:Required\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003eFeature: \u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e1.Ready-to-Go:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eThe Tuya Smart Door Sensor is ready-to-go, meaning it can be easily installed without any complicated setup or configuration.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e2.Control Channels\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e: With 2 control channels, you can easily control the door sensor from your smartphone or tablet.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e3. Alarm Alert:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eWhenever\u003c\/span\u003e\u003cspan\u003ethe sensor is triggered to open\/close, it will send alarm to alert you that someone opens your door or window.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e4. Alarm Recording:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eSupport checking open \/ close records and battery level on the app. Never worry about missing any important moments or running out of battery.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e5. Device Share:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eSelect “Home Management” in the “Me” page to share your added sensors with family members. so that they can also monitor the status of doors\/windows.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003e6. \u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003e\u003cstrong\u003e\u003cspan\u003eLow VoltageRemind:\u003c\/span\u003e\u003c\/strong\u003e\u003c\/span\u003e\u003cspan\u003eWhen battery level is low, it will automatically remind you to change batteries, never worry about running out of battery.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e7.Works with amazon alexa and Google Assistant.\u003c\/span\u003e\u003c\/strong\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e8.Enjoy Your Smart Life\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003e:When you leave home, it will push notification message to you when the door\/window opens or closes, so you can discover the intruder in time. Furthermore, you could share the device to your family members and track the history of sensor activities.\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cstrong\u003e\u003cspan\u003e9.Easy to Install:\u003c\/span\u003e\u003c\/strong\u003e\u003cspan\u003eNo complicated installation tools are required. The sensor can be installed with double-sided adhesive tape or screws(included) in just a few steps, and download an app \"tuya\" or \"Smart Life\" from GooglePlay or App Store to add the device to detect the status of your door\/window.\u003c\/span\u003e\u003c\/p\u003e\n\u003cdiv\u003e\u003cbr\u003e\u003c\/div\u003e\n\u003cp\u003e\u003cspan\u003e\u003cstrong\u003epackage List\u003c\/strong\u003e\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1xDoor Sensor (Not include battery)\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1xUser Manual\u003c\/span\u003e\u003c\/p\u003e\n\u003cp\u003e\u003cspan\u003e1xDouble-sided tape\u003c\/span\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8b978d6543d743dea98d999f471a3be8j.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S256307228a0f458e9cab10cebbab7946j.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sedb5df5b45a54f42957468cda7df5662u.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S21d03ee04cb0446ca321a63f3206e488u.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Scf17dece1b4f40888c1baf2dfe346a13l.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S15962b94f30c4cbeb9015225eb88aadf5.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S80ea674363f44c378d71d3bbee091191Z.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sc4f93083328c4d3abd62dbeb233b0104S.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S733b410e3b8b484c9dd008ecc1a2aa4aX.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/Sd2e9fa10881a4807bde8b1f83a7575aaf.jpg\"\u003e\u003cimg src=\"https:\/\/ae01.alicdn.com\/kf\/S8a904d638eda4faaba74ca582cc8ac69y.jpg\"\u003e\u003c\/p\u003e\n\u003cbr\u003e\n\u003c\/div\u003e\u003c\/div\u003e\n\u003cbr\u003e\n\u003c\/div\u003e","brand":"Ezlo - Property Empowered","offers":[{"title":"Zigbee","offer_id":51491981558053,"sku":"a20b771f-b57e-4c85-969f-ca27fb0a0030","price":13.56,"currency_code":"USD","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0771\/4632\/5285\/files\/e0ed318a8c30112a9445b09bb9b37093.jpg?v=1761926637","url":"https:\/\/shop.ezlo.com\/products\/tuya-smart-home-zigbee-door-sensor-alarm-window-door-on-off-detectors-security-protection-compatible-with-alexa-google-assistant","provider":"Ezlo - Property Empowered","version":"1.0","type":"link"}
