Shop SONOFF Simplify Your Life With The SONOFF ZBMINIR2 Smart Relay Switch
The SONOFF ZBMINIR2 is a compact smart relay switch designed to seamlessly integrate into your home’s electrical system, transforming traditional devices into smart ones with ease. Operating on the Zigbee 3.0 protocol, this SONOFF wireless switch ensures reliable and efficient communication within your smart home network.
- Ultra-Compact Design: Measuring just 39.5 x 33 x 16.8mm, the ZBMINIR2 is small enough to fit into standard EU-type, 86-type, and 120-type mounting boxes, making it ideal for discreet installations.
- Detach Relay Function: This innovative feature allows the external switch’s state to operate independently of the relay’s state. In essence, activating the connected wall switch won’t directly affect the relay, offering more flexible control options.
- Zigbee Router Capability: Beyond its primary function, the ZBMINIR2 can act as a Zigbee router, extending your network’s range and supporting up to 64 sub-devices. This ensures robust connectivity throughout your home.
- External Switch Compatibility: The device supports various types of external switches, including momentary, door, SPDT, and rocker switches, allowing for versatile integration into existing setups.
By integrating the SONOFF ZBMINIR2 into your electrical system, you can remotely control lights and appliances, set schedules, and create automation scenes through compatible Zigbee hubs. Its detach relay smart switch feature provides enhanced flexibility, enabling independent operation of connected switches without altering the relay’s state. Additionally, its ability to function as a Zigbee router strengthens your smart home network, ensuring consistent and reliable device communication.
Specifications
- Input/Output: 100-240V ~ 50/60Hz, 10A Max (2400W)
- Dimensions: 39.5 x 33 x 16.8mm
- Casing Material: Flame-retardant PC V0
- Operating Temperature: -10°C to 40°C
Incorporating the SONOFF ZBMINIR2 into your home not only modernizes your electrical infrastructure but also enhances convenience, safety, and energy efficiency.
There are no reviews yet.
