Platinum Tools RJ45 Cat5e High Performance Connector, Round Stranded (25 Pack)
(5.00)5 Reviews
In Stock
$11.95
SKU: PL106162C
The Platinum Tools RJ45 Cat5e High Performance Connector is the perfect solution for those who want to create high-quality Ethernet connections. These connectors are designed to work with round stranded cables and come in a pack of 25, making them ideal for large-scale projects.
The RJ45 Cat5e High Performance Connector is made of high-quality materials that ensure it provides a reliable and durable connection. This connector is specifically designed to work with Cat5e cables, which means it can handle high-speed data transfer rates up to 1000Mbps.
The connector is easy to install and requires no special tools or expertise. Simply insert the cable into the connector, crimp it down, and you’re done. The Platinum Tools RJ45 Cat5e High Performance Connector also features a snagless design, which means it won’t get caught on anything and will stay securely in place.
Whether you’re setting up a home network, a small business network, or a larger enterprise-level network, the Platinum Tools RJ45 Cat5e High Performance Connector is the perfect choice. With its high-quality construction, reliability, and ease of use, this connector will help you create the perfect Ethernet connection every time.
Manufacturer Part # 106162C
Plug Material Polycarbonate
Contact Material Phosphor Bronze
Plating 50µ Gold
Flammability Rating UL94V-2
Approvals UL, RoHS, FCC
Warranty 1 Year
Customers Reviews
(5)
  1. Isaac (verified owner)
    Very well worth the money.
    1 product
  2. Richard (verified owner)
    The product is firmly packed.
    1 product
  3. Kayden (verified owner)
    Good quality.
    1 product
  4. William (verified owner)
    Good service.
    1 product
  5. Owen (verified owner)
    Good service.
    1 product
Back to Top
chatsimple
