Get ready to experience the ultimate in high-speed network connectivity with the Platinum Tools Cat6A 10Gig Shielded Flex Connector. This innovative connector is designed to provide exceptional performance, flexibility, and durability, allowing you to easily install and maintain your network infrastructure.
The Cat6A 10Gig Shielded Flex Connector is engineered to deliver blazing-fast data transfer speeds of up to 10Gbps, making it perfect for demanding applications such as video streaming, online gaming, and large file transfers. It is also fully shielded to provide superior protection against electromagnetic interference (EMI) and crosstalk, ensuring a stable and reliable connection at all times using Platinum Tools Cat6A 10Gig Shielded Flex Connector.
The flexible design of the connector allows for easy installation in tight spaces, while the robust construction ensures long-lasting performance in even the toughest environments. Plus, with its single connector design, you can easily customize your network configuration to meet your specific needs.
So if you’re looking for a high-quality, high-performance connector that can help you take your network to the next level, look no further than the Platinum Tools Cat6A 10Gig Shielded Flex Connector.
Manufacturer Part # | 106230 |
Compatibility | Accommodates Cat6A and Cat7 cables up to 9.0mm with 26-22 AWG conductors |
Conductor Type | Works with both solid and stranded conductors |
Frequency Rating | Frequency rated up to 1GHz |
Certification | 10-Gigabit certified |
PoE Rating | PoE+ rated |
Michael (verified owner) –
Very fast delivery.
John (verified owner) –
Very fast delivery.
Henry (verified owner) –
Good service.
Liam (verified owner) –
Very well worth the money.
Charles (verified owner) –
Very fast delivery.
