- Communication method:Â WI-FI
- Brand Name:Â meross
- Origin:Â Mainland China
Meross WiFi In-Wall Smart DIY Switch Wireless 1 Gang 1 Way Light Switch Module For Alexa Google Home SmartThings
1. Wireless charging cable required: Before purchasing, please confirm that the original switch has a neutral cable. If there is no neutral cable, the Alexa smart switch will not work. If unsure, call a professional electrician or send us photos of the original switch connection diagrams for help.
2. Traditional switch compatible: Wi-Fi module smart switch is an upgraded version which is compatible with your traditional switch. You can use this switch module connected keeping the original switch. Keep the look and feel of your favorite switch while enjoying a smart home.
3. Voice Command Wi-Fi Connected Switch: Smart module switch is compatible with Apple Homekit Amazon Alexa, Echo, Echo Dot, Google Assistant, Google Home, Nest Hub, Nest Mini and Nest Audio, can turn the light on or off via a voice command. Meross Wi-Fi switch provides a hands-free experience
4. Remote Control Wall Switch: Download the free Meross app from the Google Store or scan the QR code in the manual. Turn the light on or off via a smartphone (iOS and Android) anywhere. Please note that this WiFi wall switch is only suitable for one-way installation, one switch controls one light. It is not intended for use in 2-way installations where the light is controlled by more than one switch.
5. Smart switch with schedule and auto-off schedule: Wi-Fi smart switch with schedule function prevents you from forgetting to turn off lights. You can create schedules to turn lights on/off automatically according to your routine. As night approaches, it’s time to turn on the lights via the Wi-Fi light switch. Meross lets you enjoy a smart life
Small but Mighty
Schedule & Fast Response & Routne Offline Execution
Remote Control & Voice Control & Smart Scenes
DIY Smart Devices & Homekit Integration
Execution & No Hub Needed & Safety
Make Old Switch Smart
Wifi Connection & Remote Control
Voice Control & Timer
External Switch Compatibility
Rocker Light Switch & Reset Light Swith
Touch Wall Switch
Remote Control
Control your light from anywhere anytime
Voice Control
Work With Siri Alexa and Google Assitant for
Hands-free Voice Control
Neutral Wire Required
There are no reviews yet.
