Shop Kwikset Traditional Smart Electronic Deadbolt Satin Nickel Lock
The Kwikset Home Connect 620 Smart Lock combines traditional design with modern smart technology. This Satin Nickel Lock offers convenient, keyless entry with customizable access codes, enhancing both security and accessibility. Compatible with Z-Wave technology, this electronic deadbolt lock connects seamlessly to your home automation system, providing control through your mobile device or voice assistant. Designed for durability and ease of installation, it features a smart code deadbolt lock, allowing users to lock and unlock doors using a 4-8 digit code, a physical key, or through a Z-Wave hub. Its sleek satin nickel finish complements various home styles, adding both beauty and functionality.
The Kwikset Home Connect 620 Smart Lock with Z-Wave 700 ensures your home is both secure and smarter. This electronic deadbolt lock offers an ideal solution for securing entry doors, combining a traditional look with cutting-edge technology. It allows homeowners to control access via a smart code deadbolt lock, which supports up to 250 user codes for family and guests. Thanks to the Satin Nickel Lock finish, this lock adds a touch of sophistication to any door.
This smart code deadbolt lock provides multiple methods of unlocking, including a PIN code, physical key, and app control through compatible Z-Wave hubs like SmartThings or Amazon Alexa. The Satin Nickel Lock is equipped with a patented Smart Key® security system to protect against tampering and ensure maximum security. Its Satin Nickel finish resists corrosion, ensuring durability and long-lasting performance, even in harsh weather conditions.
- Smart code Deadbolt Lock with 250 customizable user codes
- Satin Nickel Lock for a sleek, contemporary look
- Remote access via Z-Wave-enabled mobile apps
- One-Touch Locking feature for quick locking
- Electronic Deadbolt Lock for enhanced security
- Smart Key® rekey technology for easy rekeying
- Compatible with Amazon Alexa, Google Assistant, and SmartThings
- Lifetime mechanical and finish warranty; 1-year electronics warranty
 Perfect for homes, offices, or rental properties, the Kwikset Home Connect 620 Smart Lock makes managing access a breeze. Whether you’re home or away, control your door’s lock status remotely, and grant access to friends or service providers with ease.
- Increased security with customizable codes and app-based control
- Enhanced durability with the Satin Nickel Lock finish
- Integration with existing home automation systems for seamless operation
- Easy to install with adjustable backset and compatible door preparations
Upgrade your security with the Kwikset Home Connect 620 Smart Lock, a reliable and stylish addition to your smart home.
Manufacturer Part #: | 98930-001: Satin Nickel |
UPC: | 98930-001 (Satin Nickel): 883351793407 |
Electrical: | Input Power 6V (4 x AA alkaline batteries) |
Mechanical: | Door Prep 1 1/2″ & 2 1/8″ diameter bore hole & 1″ deep latch hole Backset Adjustable 2 3/8″ or 2 3/4″ Door Thickness 1 3/8″ – 2 ” automatic adjustment Faceplates 1″ x 2 1/4″ round corner standard Strikes Round corner strike 1 1/8″ x 2 3/4″ Latch Round corner adjustable 2 3/8″ x 2 3/4″ Bolt 1″ throw, steel deadbolt Door Handing Reversible Cylinder SmartKey® Keyway |
Environmental: | Temperature Range: Exterior: -40°F to 150°F Interior: 32°F to 140°F Humidity: Exterior: 100% condensing Interior: 30% – 95% non-condensing |
Dimensions: | Exterior: 2.81 W x 4.56 H x 1.25 D inches (71.43 W x 115.88 H x 31.75 D mm) Interior: 2.71 W x 5.78 H x 1.93 D inches (69.1 W x 146.6 H x 49.5 D mm) |
ANSI/BHMA grade: | 2 certified |
Warranty: | Lifetime mechanical and finish warranty 1-year electronic warranty |
Owen (verified owner) –
Very well worth the money.
David (verified owner) –
Nathaniel (verified owner) –
Good quality.
Richard (verified owner) –
Good quality.
Ryan (verified owner) –
Good quality.
