Shop Greenfield Automatic Security Valve Kit 3/4 In. Brass Ball Valve
The Greenfield Automatic Security Valve Kit with a 3/4 inch Brass Ball Valve is the perfect addition to any home or business that needs an extra layer of security. This kit is designed to automatically shut off water flow in the event of a leak or other emergency, preventing costly water damage.
The 3/4 inch Brass Ball Valve is made of high-quality materials and is built to last. The valve is easy to install and operate, ensuring that you have peace of mind knowing that your property is protected. The Greenfield Automatic Security Valve Kit is an essential tool for any property owner who wants to protect their investment and avoid water damage.
Key Features of Smart Brass Ball Valve:
- Automatic Shutoff: Protect your home from water damage with automatic leak detection and shutoff.
- Smart Integration: Connects easily to your home automation system for remote monitoring and control.
- Durable Construction: Made with a high-quality 3/4 inch Smart Brass Ball Valve for reliable and long-lasting use.
- Easy Installation: Designed for straightforward installation into your existing plumbing system.
Upgrade your home’s water safety with the Greenfield Automatic Security Valve Kit and enjoy the convenience and security of a smart water management system.
Product Specs:
Manufacturer Part # | ASV075Z |
Warranty | 1 Year |
Compatible Manufacturers | Leviton (HAI) Digital Security Controls (DSC) Honeywell Interlogix (GE) Visonic George Risk Industries (GRI) Elk Products, Inc. Winland Electronics Resolution Products Secure Wireless Tane Alarm Products Flair Electronics FortrezZ – MIMOlite Fibaro Actuator |
Technical Details | Housing Ratings: NEMA 6P (waterproof); NEMA 7D (ignition proof) Certifications: UL listed Input: 100-240V ~50/60Hz 1.0A MAX Output: 18V 2.22A Power Requirements: 12/24VDC or 24VAC Recommended Power Supply: PS100 Valve Certifications UL Listed VQGU – Trim and drain (US only) MHKZ – Manual valves YQNZ – Compressed gas shut-off valves YRBX – Flammable liquid shut-off valves YRPV – Gas shut-off valves YSDT – LP gas shut-off valves SFJQ – Valves, refrigerant NSF 372 NSF 61-8 NSF 61 – Annex G CSA Certified ANSI Z21.15 (.5 PSIG) ASME B16.44 (5 PSIG) CGA CR91 (5 PSIG) FM Approval MSS SP-110 |
Hayden (verified owner) –
The product is firmly packed.
Jackson (verified owner) –
Good service.
Mason (verified owner) –
Anthony (verified owner) –
Good service.
Owen (verified owner) –
Good service.
