Fibaro Z-Wave Dimmer 2
0 Reviews
In Stock
$55.18
SKU: FBFGD212
Brands:
Shop Fibaro Z-Wave Dimmer
The Fibaro Z-Wave Dimmer 2 is a state-of-the-art smart lighting solution designed to bring convenience, efficiency, and style to your home. This advanced z-wave dimmer 2 allows you to control your lighting with precision, offering seamless dimming and the ability to adjust lights remotely from anywhere in the world via your smartphone, tablet, or computer.
Key Features:
  • Advanced Dimming Control: Equipped with a built-in microprocessor, the fibaro z-wave dimmer ensures smooth, flicker-free dimming, giving you full control over your lighting environment.
  • Energy Monitoring: The integrated power metering function allows you to track your energy consumption in real-time, helping you make more informed decisions about your energy usage and potentially reducing costs.
  • Versatile Compatibility: This z-wave dimmer 2 is compatible with a wide range of light bulbs, including LED, CFL, and incandescent bulbs, making it a versatile addition to any home lighting setup.
Usage and Installation:
The Fibaro Z-Wave Dimmer 2 is incredibly easy to install and can be fitted into existing light switch outlets. Its compact design makes it ideal for use in small spaces, while its sophisticated technology ensures reliable performance. Whether you’re retrofitting an older home with smart technology or enhancing a modern setup, this fibaro z-wave dimmer integrates effortlessly with your home automation system.
Remote Control and Automation:
With Z-Wave Plus technology, the z-wave dimmer 2 can be controlled remotely, allowing you to adjust your lights from anywhere. It also integrates seamlessly with various smart home systems, enabling you to create customized lighting scenes, schedules, and automation routines.
Durability and Design:
Built with durability in mind, the fibaro z-wave dimmer features a sleek and modern design that complements any décor. Its robust construction ensures long-lasting performance, while its compact size allows for easy installation in a variety of settings.
Customers Reviews
There are no reviews yet.
• Datasheet Pdf
Back to Top
chatsimple
